Losi X2000
Old 02-24-2009, 02:26 PM
nickosclan's Avatar
Default Losi X2000
I have been running Losi X2000 on my xxxcr for awhile now. I want to switch over to the new x3000. The pins look a little bigger has any one ran these tires before? I run them in red at SRS.
nickosclan is offline
Old 02-24-2009, 02:27 PM
Hey...I know you!
Chris__RC is offline
Old 02-24-2009, 02:28 PM
Jason Pelletier's Avatar
Trader Rating: 33 (100%+)
Yea i like Pink x-3000's they are good tires.
Jason Pelletier is offline
Old 02-24-2009, 02:38 PM
You don't want to run pink compound at SRS tho. Just try them and see, it won't hurt. To be honest M3 hole-shots work the best.
I would also recomend consulting your local team driver. Wheelie knows what he's talking about... sometimes .
Joaf is offline
Old 02-24-2009, 02:44 PM
nickosclan's Avatar
I use m3 hole shots on wet track but, I am looking for a good dry track tire. I really like the X2000 in red for dry track but the X3000 look like the will have a little more traction and run time from the larger pins
Old 02-24-2009, 02:49 PM
Its always worth sacrificing a set of rims to see one way or the other.
Joaf is offline
Old 02-24-2009, 02:51 PM
nickosclan's Avatar
I guess I will just run them and see what happens. Worst case i have a good set of practice tires
Old 02-24-2009, 03:59 PM
Gliptal's Avatar
x2000's have larger sidewalls than the x3000's, I thought the pins sizes were the same. I guess I have to take a closer look.
Gliptal is offline
Old 02-24-2009, 06:07 PM
naa, those may work when holeshots don't, honestly it really depends on what your racing on. Different tires feel different in side bite and forward bite i would prolly just hold on to them. If they aren't good for the surface you will be suffering. Tires is like 80-90% of the set-up.
Old 02-24-2009, 06:12 PM
rammstein88's Avatar
that is right. Horne was telling me the team drivers would cut a couple rows out of the x2000 to obtain the desired effect...and so the x3000 was born.
rammstein88 is offline
Old 02-24-2009, 06:22 PM
rocketron's Avatar
Trader Rating: 16 (100%+)
X3000 tires are lower profile (less sidewall) than the X2000
rocketron is offline
Old 02-26-2009, 12:26 PM
Casper's Avatar
Trader Rating: 34 (100%+)
X-3000 have a different interanal design as well so they should not balloon as much as a x-2000. I would say if your track is smooth but dusty the x-3000. If it is a little more rutted the X-2000 with the taller side wall will help soak up the bumps more. The X-2000 with good traction may feel a little wandery due to the taller profile. I have liked the X-3000 when I have used them. Give them a try.
Casper is offline
