Losi e 8ight break issues
Hello Everyone,
I have an e 8ight. It is awesome, great runtime, great everything, but my breaks are way too strong. When I go over jumps it is hard to control the pitch of the car becasue my breaks are either full on or barely there. Need help. Any setup ideas. I have a 3pm radio and the Excelorin speed control.
Thanks!
Thanks!
Can I fix it by putting my ESC at 50%, than just use EPA to make adjustments from there.
I think right now I have my ESC at under 10%, and my EPA at 15%.
I programmed my drag brake to 0% on the computer. With the little field plug-in programmer you're going to have to do the EPA trick.
I can do the computer down to 0%, but what is the EPA trick?
I know that I've seen several people posting issues with the brakes, but when I received mine last week it works exactly as I would expect a brushless system. The brakes will lock up at around 90% trigger throw, and up to that point I can get a good range of braking.
Perhaps the issue comes from the transmitter not being properly zeroed out before calibrating the ESC, or the ESC may have an improper brake level set out of the box. Try connecting the ESC to your PC and adjust the brake strength and curve to default and then calibrate your ESC/transmitter again.
I'll give it try
updates on this, curious
R
R
I too have bad braking issues. The first time I hit the brakes after setting everything up, I thought I broke something. The wheels instantly came to a stop. My only solution was to turn the overall braking percentage down to almost nothing and the end point down to almost nothing. Even after doing that there is a very short burst of what seems to be full brake before it backs off to the lower braking level.
I will try to recalibrate now and see what happens.
Also, is it ok to change the curves on the radio after calibration?
The endpoints should be set to 100% for most transmitters, for the newer KO radio you should set the endpoints to 125%. Then calibrate the esc to the transmitter, and use the trim to adjust from there. If the endpoints are changed after calibration you really need to recalibrate again.
Well, I tried many different solutions at the track today, even had Horizon on the phone with me for while.
I set my break curve to a near flat line, my TX points or all at 100. The car breaks extremely strong at times, but sometimes it will just cost for a few seconds and then the break will kick in strong. It just is not very predictable. I just wanted more control when I go off jumps on the track. I guess I will just use the drag break, and get used to driving with more of it.
Open to all suggestions, would love to have this thing work well.
thanks for all input.
