Many B44 Questions >
Many B44 Questions
Many B44 Questions
Old 10-05-2008, 09:39 AM
Default Many B44 Questions
Why is the B44 so heavy in comparison to other 4WD's?
I am going to get one and after thorough reading have noticed they are heavier. But I have also read that the front ends (arms,Shafts) are the weakest link. Usually the heavier cars are more durable.
Why do 4WD's have a lower ride height in comparison to the other off road classes? Also some suggest using shorter shock shafts to make it even lower I assume. Don't you want more suspension travel with off road?
What is the best turn brushless motor and class to run the B44 in?
ESmith is offline
Old 10-05-2008, 10:01 AM
rdub202's Avatar
Trader Rating: 19 (100%+)
i dont own a b44 but ill try and answer some of these
1-are you looking at weight of RTR or roller out of the box? the b44 uses saddle packs, most with NIMH packs which will contribute to weight
2-just because the car is heavy doesnt mean the parts are strong. it could be other heavier aluminum parts making the car heavy
of course the front of the car is going to be a 'weak link' thats what you hit things with
3-im going to go with LCG for thise one. the cars are fast and agile, you dont want something tall to roll over
4-this could be a pandora's box. run what you feel comfortable in. most 4wd classes are either open/mod or 10.5 or 13.5 class
rdub202 is offline
Old 10-05-2008, 02:29 PM
Gliptal's Avatar
How heavy are the other 4WD buggies? I'm just curious, most sites don't list the weight.
I know that the B44 with lipo is close to the minimum weight though so I don't see how it matters.
As far as motor goes a 7.5 or 6.5 is good for mod class but if its a small or tight track I would go with an 8.5 or maybe even a 10.5
Gliptal is offline
Old 10-05-2008, 06:06 PM
B44 1788g (also stated in AE's website)
Hot bodies 1700g
Kyosho 1650g
Tamiya 501 1576g
As listed in R/C car magazine july 2008
These were dry weights-no battery
ESmith is offline
Old 10-05-2008, 06:55 PM
d16dcoe45's Avatar
I own a bunch of 4wds and I can tell you there is NO WAY the 501 is the lightest car in that list. 501 is probably the heaviest 1/10th 4wd car. Period.
d16dcoe45 is offline
Old 10-05-2008, 09:52 PM
astroboy403's Avatar
Tamiya is the lightest because it is a belt drive. the shaft and diff components make up most of the car.
2WD by roar rules has to be 1499 grams(52.8 OZ or 3.3LB)
4WD by roar rules has to be 1613 grams(56.8 OZ or 3.55LB)
this is ready to race, batt, tires, etc.
astroboy403 is offline
Old 10-06-2008, 03:57 AM
veecee's Avatar
Trader Rating: 34 (100%+)
+1
veecee is offline
Old 10-06-2008, 04:26 PM
nsr250repsol's Avatar
A little note about some of the other 4WD cars. Many drivers add weight to them... But really around 50-100g is nothing most club races would even nottice.
nsr250repsol is offline
