Losi 1/8 8ight E 4wd Thread
#8731
#8732
Is anyone using the "Losi Center Diff 45T Spur Gear 8E LOSA3552" in their 2.0 ?
I have recently stripped 2 plastic spur gears in a very short time at my track.
The 8E LOSA3552 metal spur seems to fit fine bit the 4 screw holes seem to be smaller than usual and won't allow for standard flat screws to tighten down fully.
I have ordered the Hot Racing 45t steel spur but want to know if the 8e losa 3552 steel spur can work too?
#8734
Thanks for the quick reply pimpedaccord, i though it should work. I used some button head screws to seal the gaps and no leakage after about 20 min of lap practice today and everything seemed fine.
#8735
I have been using the 44t plastic spur for a few months now with no problems. Make sure your gear mesh is right.
#8737
Ive never had a problem with plastic spurs.. most of the time people see diffs leaking as there is some fluid slung out on the chassis or other places. If you overfilled it and some seeped out the side, that will sling all over. Make sure your not overfilling it to, that can be a culprit.
#8738
6 or so years of running E buggy and ive been through a whopping 1 spur gear, And that was when the motor came loose off the mount.
IMO there is NOTHING wrong with the plastic spurs what so ever, Metal is Significantly louder and Will eat pinion's over time VS the plastic which can go 100's of packs without any worry.
#8740
#8741
Hi
I need a replacement motor for my losi 8 e (1.0)
The stock one has a 24mm long shaft and i cant find any good alternatives.
Thanks in advance, tried to find it in the 500+ pages but the serch didnt help
#8742
Any 1/8 scale motor should work. I have used a few different motor without any issues with the shaft being too short.
#8744
