Losi 1/8 8ight E 4wd Thread >
Old 07-31-2014, 07:16 AM
  #8881
Integra's Avatar
Originally Posted by RevolutionM View Post
What is the part number for a metal spur gear that will fit a Losi 8 E 3.0?
LOSA3552 45T
Integra is offline
Old 08-06-2014, 07:55 AM
  #8882
TahoeDust's Avatar
Hey guys. This is my first post on this forum. I am not sure if this is the right thread, I did not see one dedicated to the 8ight-T so maybe you can help me out. I am converting my 8t this week an am looking for a suggestion for gearing. I am going to be running a Hobbywing 150a xerun, a Hobbywing 1800kv motor, and using 4s 5000mah Lipos. The truck will be 80% track and 20% bashing.
TahoeDust is offline
Old 08-07-2014, 12:52 AM
  #8883
I run a metal 45 tooth spur gear and a 16 tooth pinion. I have the same ESC you're wanting to run, but I run the 2200kv motor in mine.
https://www.youtube.com/watch?v=Qugo...dtfwzKHKCxGPZA
Brushless Corey is offline
Old 08-27-2014, 07:39 PM
  #8884
Guys i need to refresh my diffs are the rtr and race diffs the same? Im just going to replace all 3 and need to find the cheapest route.
g-one is offline
Old 08-27-2014, 07:48 PM
  #8885
Trader Rating: 17 (100%+)
Most RTRs come with black grease in the diffs. Just clean the gears and diff cups really good. I normally use brake cleaner because it blasts it out as well as cleans off the side of the diff cups. Make sure to clean the lid as well. Then fill with diff oils. 5000 front 7000 center and 3000 rear are good starting points. Drake uses 2000 in the rear. That is the cheapest way.
hpiaddict is offline
Old 09-15-2014, 06:53 PM
  #8886
Tom-sct's Avatar
Default 8ight 2.0
Hello guys.
I just bought a used Losi 8ight e- 2.0 buggy.
It looks just like the one on the 1st. page of this thread.
A couple of questions: What up dates/improvements are the most important to get this buggy up to 3.0 spec. ? (shocks, chassis etc.)
Also where can I find a set-up sheet for indoor for this buggy.
Everything on Losi's site is for the 3.0
Thanks for the help.
Tom
Tom-sct is offline
Old 09-16-2014, 12:56 PM
  #8887
dtr
dtr's Avatar
Horizon's site has some setups.
dtr is offline
Old 01-14-2015, 12:29 AM
  #8888
Suspended
Trader Rating: 440 (99%+)
Anyone wanting a bearing kit for a 8ight 2.0 hit me up. I have a new 58 piece kit that I'm selling for cheap.
http://www.rctech.net/forum/r-c-item...l#post13780074
MattP is offline
  #8889
Suspended
Double post by accident.
MattP is offline
Old 01-14-2015, 12:50 AM
  #8890
rodricklinderRC's Avatar
The diff are the same in the rtr and race kit.They do make smart diff for the race kit it is a optional.
rodricklinderRC is offline
Old 07-31-2015, 06:46 AM
  #8891
Hey guys,
I have converted a 2.0 to E with losi conversion kit. Using the proline bulldog nitro body, it budges kinda to the battery side.
Its hobbyking 4500mah hardcase, 45mm height.
I wont be able to get the E body till a weeks time, im assuming the e body has higher side clearance for the battery? :S
Vinno is offline
Old 07-31-2015, 11:51 AM
  #8892
dtr
dtr's Avatar
Those packs will fit under the E body, unless you want to put them all the way forward.
dtr is offline
Old 08-01-2015, 07:47 AM
  #8893
Thanks, is their a general battery guide height size for battery that fit under the e body?
Vinno is offline
Old 08-01-2015, 01:10 PM
  #8894
dtr
dtr's Avatar
None that I know of
dtr is offline
Old 09-11-2015, 04:47 AM
  #8895
spookie's Avatar
Trader Rating: 25 (100%+)
Anyone know if a 8 3.0 body will fit pretty well on a 2.0? It looks blocky in the pics compared to a 2.0?
spookie is offline
