Losi 1/8 8ight E 4wd Thread
#3121
Which springs do you use?
Greetings,
Looks like all the setup sheets on Losi's website use the silver springs up front (Drake, Hodges & etc). I do not have the 2.0E race roller but have built my own conversion which now has all the 2.0 parts. My problem is that those silver springs up front offer me no rebound. My setup should not be any heavier than the factory Losi setup so do not understand what is the deal.
I have been thinking of giving the green ones a try up front. What do you guys use?? Any input will be helpful. Cheers!
#3122
Greetings,
As for no rebound with the silver springs I'd bet you have something binding. Check all the usual suspects: Bent shock shafts, Bent hinge pins, Ream the hinge pin holes thru the arms, Make sure the swaybar moves freely, Inspect the CVDs and dog bones for wear.
#3123
I have a 1.0 with some 2.0 parts and a flex tune chassis. On bigger tracks I like the more controlled feel of greens on front. The car feels more solid and consistent. However on tracks with tighter turns or more than one 180 I like the silvers on front because they just turn more. If you like the greens try running the softest front swaybar or no front swaybar to get more steering.
#3126
#3127
I want to convert a losi 8ight-t 2.0 ... Does the LOSA8097 e-buggy body fit on the 8ight-t 2.0 ?
#3128
i found the 1.0 arms did this a lot more frequently then the 2.0's...my 2.0's are still strait as an arrow.....they changed something in the plastic blend for sure.
buggy body on a truggy ? Huh
#3129
Is there a E-truggy-body available ?
#3130
#3131
Do they make a 46t plastic spur?
#3133
Well i finally pushed the GO button on my electronics for my E 8ight......i went with a Tekin 1900 that i plan to run 4s 5000's......i got all 3 spur's and a 14t 15t 16t pinion's to make sure i gear it right....any other tips when installing ?
#3135
