Losi 1/8 8ight E 4wd Thread
#2881
Guess I should've said IF you wanna charge at 5 amps, you'd need a higher wattage charger, not "you need a new charger."
#2882
just got to run my 8ight e 2.0 and love it.got a couple questions,
1.was running about 160 with the 15t stock xcelorin system,is that ok?what are some running temps out there?
2.also i have an ice charger with an inline balancer.will that charge the losi 4 cell 5000 batt ok?
thanks for your help.
#2884
Will at 1700kv 4s geared at 17/45 final tranny rpm of 9530 run hotter than a:
1700kv 5s geared at 14/45 with a final tranny rpm of 9797?
#2885
R/C Tech Elite Member
#2886
The 2.0 chassis is a little bit longer. The 2.0 A-arms use different sized hinge pins, different servo saver setup, etc.. Many of the parts are the same though. From what I hear there are enough parts differences to make it too expensive (not practical) to upgrade entirely. I got the 1.0 because I got a great deal on a used roller. I would recommend trying to get the newer 2.0 version, but there are great deals to be had getting a 1.0.
#2888
My guess is that the 2.0 probably handles different/better because of the different chassis size. My 1.0 handles pretty well though and I'm happy with it.
I'm going to upgrade certain parts to 2.0 a little at a time.
#2889
the 2.0 buggy may appear similar but when compared side by side there's a significant difference in handling and performance.....my vote is to go 2.0.
the buggy is doable to upgrade over time...its the Truggy that imo is a wash and should be bought as a kit as the list of required parts is pretty steep.
#2892
I figured there would be difference in handling. I'm going with the 2.0 upgrade over time, deal.
#2893
ok guys raced my 8ight e 2.0 tonight for the first time and all i can say is power power power.i run a big loamy track and would like some setup advice.this car is gonna take some getting use to driving compared to the nitro but i love it.all setup help is greatly appreciated
