Losi 1/8 8ight E 4wd Thread
#151
is it me or does Topas's pictures show the new losi 2.0 diff cups?
#152
Dear Mr. Hodge,
let me post some experiences . I think I am the first person in germany who owns an 8ight-e which I received this week from amainhobbies.
First of all I have to admit, that the overall hardware quality is very good (only a screw was worn out and the wheels are glued so bad that I lost 3 on the racetrack!) but the brushless components are not what I expected from your company.
Sadly the ESC stopped working BEFORE the first run outside...
I connected a 5s lipo and drove some seconds in the house - suddenly the car went to full throttle , hit my leg and awful smoke came out of the ESC ...
This weekend I used a MGM 22418 on a 4s 30C Lipo instead of the original ESC and switched to a 11 tooth pinion (Novak - this was the only available pinion for me at the moment).
I donīt know why the car is shipped with a 16 tooth pinion but the manual at : http://www.losi.com/ProdInfo/Files/1...otorManual.pdf recommends max. 13 tooth at 4s !
On friday I called the losi service center and was told to send the ESC back - they also told me that it is not possible to send me a working ESC in advance / on the same time I send out the defective one. (I am very disappointed)
A last question:
Did I spend 879 for an outdated 8ight-e V1 and will the 8ight-e V2 be available soon ?
Here are some pictures :
A last question:
#153
Mr Hodge
What set up should be used for the e8
I tried the race roller set up but feels soft and lands hard on big jumps
I am very happy with the e8
I have wanted to convert my nitro since last year but I waited for Losi to do the research and looks like I made a good decision
Other racers were test and tuning while I was just charging and plugging in
Some info I learned
The plugs for the battery are huge to charge I had toput the female plugs on with the banana plugs to fit the Losi plugs
Check tires one came unglued
Unfortunately I did not check how much amps I used will do next race
Some info I learned
#154
When will they come out with a E-8ight-T or the E-8ight 2.0?
keep up the hard work.
#155
Will the electric conversion kit work with the new 8ight 2.0 when its released? Or will it only work on the original 8ight and 8ight-T
#156
@hodge
"I donīt know why the car is shipped with a 16 tooth pinion but the manual at : http://www.losi.com/ProdInfo/Files/1...otorManual.pdf recommends max. 13 tooth at 4s ! "
Can you answer this question ?
#157
depends on how 'different' the 2.0 is. if its way different, then simply they wanted to get rid of their old stock and hopefully get a premium for them in electric form then as 'last years' buggy. if its not much different then perhaps ur in luck for another year til the next 1 comes out....but again, if it not much different, the thought of the 650$ price level thats floatin around seems to be borderline on gouging for an 'evolution'.
granted that only happens were all dumb enough to continuously by the lie (i mean hype).
R
R
#158
#159
@hodge
#161
Does the 50T losi spur fit with the motor mount setup? Or the kyosho 46T spur?
#162
I have a new 8ight e and i am just reading the thread and trying to learn a little about it been racing nitro but gonna race them both. Can't wait. Any good advice before i start anything.
#164
i use the kyosho 46t. it fits real well, never any leaks really with mine. ive been running a custom e-8ight for almost a year now and love it. the only leaking ive had is when i change diff fluid and dont replace the seal and inner o-ring every once and awhile, but thats also just normal maintenence. i can usually get 2-3 changes out of one set. although that 3rd time is starting to get bad though.
#165
Does anyone know if the 8-E comes with the gearbox upgrade that the new 8ight comes with? What was the reason it was upgraded? Has anyone had any trouble with the diffs or any part of the drive train while running brushless? Thanks. Trying to decided whether or not to buy one of the nitro kits since they are cheap right now with the new buggy coming out.
