Traxxas Slash, SETUPS ONLY ! ! ! ! !
#346
Suspension:
all rpm arms
aluminum hub carriers
aluminum caster blocks
losi 8ight shocks silver springs 25wt rear 20wt front
Drivetrain:
mamba max 7700 motor and esc
4500 mah 30c lipo 7.4v
Wheels and tires:
proline switch tires
proline bead lock wheels.
Proline desert rat Body
this is what i run on mine. It is a lot of stuff but it is really worth the $$.
all rpm arms
Drivetrain:
Wheels and tires:
#348
Suspension:
all rpm arms
threaded aluminum integy shocks with 60wt oil. Stock springs that were on the ultra shocks.
Drivetrain:
4500 mah 30c lipo 11.1v
Wheels and tires:
all rpm arms
Drivetrain:
Wheels and tires:
What's your gearing?
Pic/Video?
#349
Oh in case anyone needs/wanted to know...it may seem commonplace but I found you can mount rear rustler rims all the way around the slash and fit normal truck tires (such as Proline + J Concepts + Panther) no modifications.
Makes the truck easier to drive when/if you are running in a more open class that allows "other" tires.
My son runs novice (read, not spec/slash) and it really made his truck easier for him to drive, as we all know the compounds/tires are "better" than the stock/spec type.
I also put XXXT shocks all around for him
For what its worth.
For what its worth.
http://www.rctech.net/forum/r-c-item...ess-slash.html
listed for sale for two weeks, pointing out that it uses Rustler rear rims and showing they fit with a top view shot.
They do work great.
#350
Location: Abrams, WI (Yes the same town as CJ & John Greaves)
I also noticed the T-Maxx shocks appear to be the same on the back of the Slash. So if you have a T-Maxx, you have a few spare shocks if you need them.
#351
The rear shocks already have a small blue bumper in that spot, but I basically wanted it longer and used the fuel tubing idea. I don't know how well it works yet; jury's still out on this one.
#353
#354
I never had a problem with the tires pulling off the bead but im sure it is possible. Since i use my slash mostly for bashing i like to have plenty of power. You might say its overpowered but is a kick lol. Since my first rc was a nitro 4 tec 3.3 i like my rc cars to be around that same speed.
#355
motor
GTB with a 10.5 novak brushless
on the edge of overpowered for my local carpet track
batt, radio
xr-s sycrnized fm
orion 4800 lipo 25c
suspention
front-traxxas alu big bores, 50 wt oil-pink losi springs-1 hole piston
rear-stock platic 50 wt oil, stock springs, 1 large spacer-2 hole piston
has alot of body roll but everyone at the track agrees that u must have the roll to help the traction rollovers
batt, radio
xr-s sycrnized fm
orion 4800 lipo 25c
suspention
#356
What mod is required to run Diff oil in the Slash? I have a bottle of 250,000wt. coming in Wednesday.
Are you guys really seeing a great improvement with heavy weight shock oil? I'm running 20/35 and love the setup. There is only one jump at the local track I will bottom out on and that is still rare. I'm actually thinking of running 20/30 in the near future.
#357
I just put 120,000 wt ofna in my diff on thursday. Ran it on saturday 4-packs
and broke it down last night. NO leaks I was very suprised to see this I had expected something to come out.
When i did it I took it out , cleaned all the diff parts with motor spray , put it back together ,filled it about half full and put the cover on.
I put the 4 screws in being careful not to overtighten them and then I put a drop(small) of tireglue on the edge and turned the diff untill the glue went all the way around to make a seal. Worked great and easy to break loose if needed. I do not think I will have to mess with this again.
I am very pleased with the difference . Good luck
@ the oil, 45 wt on all 4.
I will be going up to 55 rear or staying and going to 1 hole pistons
as our track has alot of big jumps
#358
Mostly stock for now
RPM Parts:
A-Arms
Front shock Tower
Rear Hub carrier
Front caster
Gear cover
Motor mount
50/60 wt oil in the shock
Everything else is relatively stock for now. I plan to run aluminum belcranks in the future. Also a brushless system will be added, along with Integy piggy back shocks, RPM rear shock tower, try to convert the hubs to 17mm and run buggy tires, Proline Desert rat body, MIP CVD, Ball Diff.
A-Arms
Front shock Tower
Rear Hub carrier
Front caster
Gear cover
Motor mount
#359
Does anyone know the width of the battery area (from left to right) on the Slash chassis in millimeters? Trying to see if a certain lipo will fit...
#360
Suspended
slash/slayer wheels
Does any body know if the back spacing on the slash is the same as the slayer ?
