What's your 1/8th electric selections?
#76
1. 8ight-T
2. Novak 6.5 HV
3. HV Pro
4. Dual SMC 5000 28C
5. Venom Pro Charger
6. Novak
7. 2 - 40mm
8. Great handling and acceleration. I give nothing up to nitros in terms of speed or handling. The instant torque allows me more room for error on a technical track.
9. Fans are necessary to keep it cool, but break a lot. Batteries and motor on same side, making the car slightly left heavy.
10. Plenty of power but not so much I can't control the truck.
11. approx. 16-18 mins racing
12. 11/48
2. Novak 6.5 HV
3. HV Pro
6. Novak
7. 2 - 40mm
12. 11/48
#77
UPDATE:
1. <Car> Mugen MBX6
2. <Motor> NEU 1512 1.5Y
3. <Speed controller> MMM V3
4. <Lipo Battery> ZIPPY-H 5s 3300mah and 4000mah
5. <Charger> Hyperion 610i dual
6. <Conversion Kit> RC Monster
7. <Cooling Fan> 25mm
8. <Likes of your setup> MUCH MORE CONVENT than Nitro. Tons of bottom end. Top end is on par with the fastest Nitro.
9. <Dislikes of your setup> Can not run virtually infinitely like Nitro. but no big deal
10. <Description on your motor performance> Look at Likes of setup
11. <Battery Life> AVG 190 to 200 mah/minutes. 3300 about 13 minutes 16 minutes for 4000 pack
12. <Pinion/Spur> 14/46 (est @ 41mph)
1. <Car> Mugen MBX6
#78
1. <Car> Losi 8ight
2. <Motor> NEU 1512 2D/F
3. <Speed controller> MMM v3
4. <Lipo Battery> Maxamps 4S 5000mAh
5. <Charger> Hyperion 0606i l
6. <Conversion Kit> Losi
8. <Likes of your setup> Brushless. I have tuned all kinds of engines but never a Nitro R/C. No garage to store fuel so brushless it is!
9. <Dislikes of your setup> Brushless creates serious heat and who likes to wait around for batteries to charge?
10. <Description on your motor performance> Massive.
11. <Battery Life> Hope to get 20 minutes on large track.
12. <Pinion/Spur> 13/44 (est @ 45mph?)
#79
rc8
neu 1512 1.5d
mmm v1
thunder power 5000 4s 25c
duratrax ice-DNPower balance charger
25mm on top of esc connected to reciever
monster rc motor mount and batt tray, my top .plate
smooth, fast, handles like a 1/10th scale, and oh yah it's brushless!
the esc had a problem with lvc.
all the power I need
I use my transmitter timer @ 15minutes and don't race longer
12-14/44 depending on the track
neu 1512 1.5d
mmm v1
#80
Well... the buggy should be here by Wednesday... still working on motor & ESC selection, so what's listed is tentative Any advise is always welcome
1. <Car> Caster Fusion EX-1
2. <Motor> Medusa Afterburner V2 36x60mm 2000Kv 5mm Shaft
3. <Speed controller> Mamba Monster V3 with onboard BEC
4. <Lipo Battery> (2) Diggity Designs 5300mAh 28C 7.4V
5. <Charger> FMA Direct Scorpion
6. <Conversion Kit> None - Factory Built!!
7. <Cooling Fan> Hopefully none will be necessary
8. <Likes of your setup> Balanced battery setup
9. <Dislikes of your setup> That I don’t have everything I need yet
10. <Description on your motor performance> UNKNOWN
11. <Battery Life> Hope to get 20 minutes of good runtime
12. <Pinion/Spur> 13T/44T
#81
1. <Car> 8ight
2. <Motor> Neu 1515/1.5D gear 16/45
3. <Speed controller> Quark Monster Pro 125B
4. <Lipo Battery> 3S 11.1V 5000 MAH from Max Amps
5. <Charger> Astroflight
7. <Cooling Fan> None
8. <Likes of your setup> Well balanced layout; the Losi motor mount is great and well made; the quark speed control mounted on the Losi battery tray with only minor modifications; fit and finish is nice.
9. <Dislikes of your setup> The Losi motor mount is designed for 4mm motor screws but the Neu motor has 3mm motor screws; the battery tray is brittle a broke after a good tumble.
10. <Description on your motor performance> The motor performs very well on and indoor track with only a 3S Lipo. It's on par with the nitros on top end and accelerates better. On a larger track, gearing up or moving to a 4S would be necessary to increase top end speeds.
11. <Battery Life> I haven't raced it yet, but I expect it should easily reach 25 minutes. I'll let you know.
#82
UPDATE:
1. <Car> Mugen MBX6
4. <Lipo Battery> ZIPPY-H 5s 2600mah, 3300mah, and 4000mah
1. <Car> Mugen MBX5T
2. <Motor> NEU 1515 2.5D
6. <Conversion Kit> Teckno RC
7. <Cooling Fan> 40mm
8. <Likes of your setup> Not sure
9. <Dislikes of your setup> Not sure
10. <Description on your motor performance> Not Sure
11. <Battery Life> Not sure
12. <Pinion/Spur> 14/46 or 13/46
1. <Car> Mugen MBX6
#83
1. <Car> X-Ray XT8
2. <Motor> Nue 1512/1.5d/f
3. <Speed controller> MMM v2
4. <Lipo Battery> Elite 4s 4800 30c
6. <Conversion Kit> Rc-Monster
7. <Cooling Fan> Stock on ESC
8. <Likes of your setup> Power!!!!!!!!!!
9. <Dislikes of your setup> None
10. <Description on your motor performance> Just sick I tell ya!!!
11. <Battery Life> 12 minutes on tacky track and 15 on loose track.
12. <Pinion/Spur tooth> 12/50
#86
1. <Car> ------------------------------Losi 8ight buggy
2. <Motor>----------------------------Mamba Monster 2200kv (MMM combo)
3. <Speed controller> ------------------Mamba Monster
4. <Lipo Battery> --------------------Zippy-H 5000 4s
5. <Charger> --------------------------Hyperion Duo
6. <Conversion Kit> --------------------Team Losi
7. <Cooling Fan> ----------------------None
8. <Likes of your setup>---------------dependable castle service and horizon service A+
9. <Dislikes of your setup> ------------In process of assembly right now
10. <Description on your motor performance>-----In process of assembly right now
11. <Battery Life>------------------To be figured later (guessing10-20)
#87
1. <Car> Losi Eight-E
2. <Motor> Losi 2200kv
3. <Speed controller> Losi
4. <Lipo> Losi 5000 4s, Zippy pack 5000 4s
7. <Cooling Fan> Losi
8. <Likes of your setup> fast motor, no problems with heat, factory assembled
9. <Dislikes of your setup> a bit heavy with losi 5000, needs stiffer springs up front
10. <Description on your motor performance> good, have had no problems running 15 mins in 80-90 degree heat, esc 120s, motor 140s
11. <Battery Life> 15 - 19 min
12. <Pinion/Spur tooth> 16/48? (stock losi E-8)
1. <Car> 8T
2. <Motor> MMM combo 2200
4. <Lipo Battery> Losi 5000 4s
6. <Conversion Kit> Techno with clutch and brake
7. <Cooling Fan> mmm
8. <Likes of your setup> still working on it right now, will use truhe's
11. <Battery Life> will see this weekend or next race day
next project
1. <Car> HB D8
2. <Motor> Neu 2050kv
4. <Lipo Battery> Reedy 5000 2s x 2
5. <Charger> hyperion
6. <Conversion Kit> Techno with no clutch
7. <Cooling Fan>
8. <Likes of your setup> I like how the D8 runs and handles in nitro might be better if converted to electric
11. <Battery Life>
1. <Car> 8T
next project
1. <Car> HB D8
7. <Cooling Fan>
11. <Battery Life>
#88
1. MBX5T
2. Neu 1515/2Y
3. My own LT-10S-120A
4. 2 4S Enerland for a 8S set up
5. Astro Flight 109
6. Mr. C V1 MBX5T kit
7. Not needed
8. All the power I need at very low AMPs
9. Nothing
10. Motor makes a lot of torque, runs very cool even after more then 30 min.
11. Over 30 min. run time
12. 15T (RC-Monster)/48T (Steel Losi SPur)
2. Neu 1515/2Y
5. Astro Flight 109
7. Not needed
9. Nothing
#89
UPDATE:
1. <Car> Mugen MBX6
8. <Likes of your setup> everything you would dis-like about nitro
9. <Dislikes of your setup> does front flips when breaking fully at top speed. easy to fix via controller.
10. <Description on your motor performance> Massive bottom end. thinking of going up a tooth or two on the pinion.
11. <Battery Life> around 240-250 mah
12. <Pinion/Spur> 14/46 or 13/46 => going to either 15 or 16T pinion
New Project although not 1/8th scale
1. <Car> Xray M18T Pro
2. <Motor> NEU 1100 series
3. <Speed controller> CC micro pro
4. <Lipo Battery> hobbycity 2S/3S
6. <Conversion Kit> None needed
7. <Cooling Fan> thinking of 30mm fan
8. <Likes of your setup> haven't ran it yet
9. <Dislikes of your setup> haven't ran it yet
10. <Description on your motor performance> haven't ran it yet
11. <Battery Life> haven't ran it yet
12. <Pinion/Spur> haven't ran it yet
1. <Car> Mugen MBX6
#90
1. <Car> 8ight conversion
2. <Motor> Medusa 2000 kv v2 60 mm
4. <Lipo Battery> ZIPPY-H 4s 5000mah
5. <Charger> gt power a6
6. <Conversion Kit> losi
7. <Cooling Fan> none, except MMM stock
8. <Likes of your setup> convenience
9. <Dislikes of your setup> Battery charging time
10. <Description on your motor performance> Really fast. Stays pretty cool
11. <Battery Life>18-20 min
12. <Pinion/Spur> 15/45 (est @ 42mph)
