What's your 1/8th electric selections?
#32
1. <Car> Losi 8ight Truggy
2. <Motor> TeknoRC (NEU) 1515 1Y
3. <Speed controller> CC Monster Max
4. <Lipo Battery> Looking into A123 but most likely Maxamps 6000mah 5S2P
5. <Charger> Still deciding
6. <Conversion Kit> TeknoRC V3 Brushless
7. <Cooling Fan> Looking for 40mm for motor
8. <Likes of your setup> Parts in mail
9. <Dislikes of your setup> Parts in mail
10. <Description on your motor performance> Parts in mail
11. <Battery Life> Any guesses with my setup and battery?
Obviously I am waiting on the new Monster Max's ESC to come out, hopefully they won't fail now. Also the TeknoRC NEU motor and conversion kit should hopefully ship within a couple of weeks.
I have a few questions for those more experienced with electric 1/8th. Is the Monster Max built in fan good enough or is another fan required? I will be running the truggy in Iraq where it gets pretty dang hot outside! Will the 1515 1Y running at 18.4 volts be pretty quick or do you think I should upgrade to 6S lipo's? What would be one of the best AC/DC Lipo/LifePo4 chargers you would recommend for under $300? Does anyone know with the TeknoRC electric clutch system if I will still have reverse capability? Would you recommend a seperate BEC and not tap off the Monster Max to keep temps down? I might even consider a seperate Rx pack.
That's all that I can think of for now.
#34
1. RC8 (building it now, previously the car was a Jammin)
2. Neu 1512 1.5Y
3. Tekin R1 Pro
4. Poly RC 6000mah 4s (overkill, about to buy an Elite 4800 as a 2nd batt.)
5. ICE
6. RC-Monster.com
7. 2 25mm Much More Hi-RPM
8. In the Jammin, the power was smooth, instant, and still controllable.
9. Battery is pretty heavy, but Like I said, it is overkill.
10. Smooth, Easy to drive. TONS of low end. But if I wanted to gear it up and have TOP, I could.
11. 25-30 minutes on the 6000. Probably 15-20 on the 4800 I am guessing.
2. Neu 1512 1.5Y
3. Tekin R1 Pro
5. ICE
6. RC-Monster.com
#35
Tech Legend
For charger, I would go with a Hyperion 610i . Excellent charger. If you wnat to charge more than one pack, look into there duo model. I use this with an MRC power supply and it works great.
#36
I ordered the Hyperion 610i Duo. Seems to be one of the best chargers out there.
#37
#39
1. Car: Losi 8ight
2. Motor: Novak HV 4.5
3. Esc: Mamba Monster
4. Battery: Neuenergy 4s 4100mah 30C
5. Charger: Ice
6. Conversion Kit: RCM motor mount, homemade battery strap.
7. Cooling fan/heatsinks: None
8. Likes: Light weight, 7.1-7.4lb rtr, fast, durable, reliable, simple.
9. Dislikes: Hard to gear down properly for tighter running areas.
10. Motor Performance: greater than 45mph no matter what gearing used, wheelies from standstill, runs about 160-170F.
11. Runtime: 12-15 minutes.
I'm actually going to exchange my HV4.5 motor for a HV7.5 motor and get the castle neu 1512 1Y. I may also run 5s on both motors and get a hyperion charger. I mainly bash, so capability of high speeds are somewhat of a priority.
5. Charger: Ice
#40
Here is my setup
1. Losi 8ight
2. Neu 1512 2d/f
3. Tekin R1pro (with 2 caps 35v 2200), case mod (holes in case for cooling. Receiver pack Nimh.
4. Polyquest 4s 6000, Elite 4s 4800
5. 2-Astro flight 109's
6. Monster motor mount, RCPD standard tray- long, center diff top plate/ESC mount (Dan's).
7. Yes, fan blows directly on solder posts on ESC.
8. Pretty fast, but not too fast, Everything has been working great.
9. Would like to get a little more runtime for longer mains, I need the fan to keep the ESC temps in check (or should I say to keep it running cooler), I can run without the fan but it pushes the ESC a little hotter than I like and would like to get away from the fan.
10. Motor's performance is.. what can I say the Neu's run great... but should have gotten the Neu 2.5d to get more runtime on my 4s setup
11. With the Polyquest 6000 I can get about 15 minutes + but need to run it on a large track to check runtime on a larger track. Elite 4800 just over 10 minutes (pack is getting weak).
12. gear ratio: 12/46 (kyosho spur)
1. Losi 8ight
2. Neu 1512 2d/f
#41
1. <Car> Mugen MBX6 (just got it today)
2. <Motor> Either NEU 1512 3D or 1509 1Y (do not have yet)
3. <Speed controller> MMM (do not have yet)
4. <Lipo Battery> Neu Energy 5s 5000mah (do not have yet)
5. <Charger> Hyperion 610i dual (on the way)
6. <Conversion Kit> RC Monster (on the way)
7. <Cooling Fan> 30mm for motor (on the way)
8. <Likes of your setup> In progress of putting together
9. <Dislikes of your setup> Same as above
10. <Description on your motor performance> Same as aboe
11. <Battery Life> Same as above
#42
1. <Car> Eight
2. <Motor> Neu 1512 1.5
3. <Speed controller> MMM / MM
4. <Lipo Battery> Flight Power 4s 5000, Zippy R 4s 4800
5. <Charger> Ice
6. <Conversion Kit> RCPD
7. <Cooling Fan> Novak 25mm
8. <Likes of your setup> everthing
9. <Dislikes of your setup> Not a thing
10. <Description on your motor performance> BMF !
11. <Battery Life> 20mins
5. <Charger> Ice
#43
1. <Car> Caster Fusion EX-1
2. <Motor> Medusa 2000kv
3. <Speed controller> Mamba Max w/ Castle BEC
4. <Lipo Battery> 2 - Core-RC 3250 (Not sure what upgrade path I wanna take)
5. <Charger> 1 of 3 either a Checkpoint, Ice, or G.T. Power A8
6. <Conversion Kit> None (Factory Built!!)
7. <Cooling Fan> 30mm on ESC. Haven't seen it over 145 deg F.
8. <Likes of your setup> Great balance. Very stable landing due to big bore shocks.
9. <Dislikes of your setup> Pushes just a little. Just need to work on setup a little.
10. <Description on your motor performance> Runs cool and efficiently. After a full run motor temps in the mid 130's.
11. <Battery Life> Get close to 15min of racing on my little 3250 packs.
Pics are pre ESC fan, and big bore shocks.
#44
This sorta my dream ideal setup.
I'm still waiting on a reliable ESC to come out, I dont really wanna mess with returning fried ESCs or soldering thicker wires to MM and getting external BEC. =/
Until that happens, this will remain as a dream only.
1. <Car>8ight 2.0
2. <Motor>Neu 1512 3D/F
3. <Speed controller>MMM, whatever version is finally as reliable as MM
4. <Lipo Battery>PolyQuest 25C 5S 4350mAh
5. <Charger>iCharger 106B+
6. <Conversion Kit>RCPD kit or 8ight Electric Conversion kit (undecided)
7. <Cooling Fan>None!
8. <Likes of your setup>It's perfect, in theory. =D
9. <Dislikes of your setup>Too expensive and untested.
10. <Description on your motor performance>Can't say, but hopefully great.
11. <Battery Life>Unknown, but hopefully slightly over 20 minutes due to higher efficiency of higher voltage (in theory).
1. <Car>8ight 2.0
#45
1. <Car> Caster Fusion EX-1 sport
2. <Motor> Medusa 36 60 2000kv
4. <Lipo Battery> 2 - Maxamps 6000maH
5. <Charger> Ice
6. <Conversion Kit> None required (Factory Built!!)
7. <Cooling Fan> None required
8. <Likes of your setup> Best balanced and handling buggy I have ever driven.
9. <Dislikes of your setup> Plugging in batteries is a lot more challenging than tuning a motor....NOT! (I don't have the pro kit yet)
11. <Battery Life> Get over 25min of racing on my packs, but I believe that slow is fast....
By the way, orange is faster than blue or yellow...
Mike Mazza
Caster Racing USA
5. <Charger> Ice
Mike Mazza
Caster Racing USA
