ESC
ESC
with the Airplane brushless ESC getting cheaper everyday like asian made +100amps are below 100$ combining this with fegiao inrunners which will be below 150$ less reverse and brakes course. would this be possible setup for a 10/buggy just for bashing? how much is the minimum ESC amp rating be?
the problem with aeroplane ESC's is that they have a soft start, so the voltage will slowly increase to full power, and your buggy/truck will come off the line slowly. it would work, but not have the performance you require.
but isn't that the bonus on soft grounds and easier on the drivetrain? plus its a lot cheaper....
how do you set a moped V16r
Hi does anybody know the procedure to set a moped v16r esc with the transmitter your response will be much appreciated.
