Team Associated B44 is for REAL >
Old 11-05-2007, 08:53 PM
  #751
ben73's Avatar
Trader Rating: 40 (100%+)
Originally Posted by sipaboy
By using the JC ball cups you cannot use the stock turnbuckles for the rear. You need to get a short one[turnbuckles]. The rear stock turnbuckles won't work. Hard to find a blue turnbuckle that short.
no, its really easy its a 1" associated part. its the same blue as the rest of the turnbuckles
ben73 is offline
Old 11-05-2007, 10:10 PM
  #752
jasburrito's Avatar
Originally Posted by ryno529
I was putting together the front gear box/diff and used the shims ae suggested in the maunal but found the gear mesh too tight.is this normal?i think it would create excessive wear? i moved the gear outward 2 shims and the pinion i removed one shim it feels a lot better.just curious what others are doing.i would also guess you need to re shim everything after a few runs as well?since the gears are plastic
Look at the back of the pinnion gear!!!!!!!!!!! Mine had flashing that needed to be removed.
jasburrito is offline
Old 11-05-2007, 11:57 PM
  #753
Soupermike's Avatar
Has anyone tried running the sway bar yet? i'm gonna try it out this weekend
Soupermike is offline
Old 11-06-2007, 09:03 AM
  #754
kdub's Avatar
Default Do not change B44 gear shimming.
ATTENTION: Do not change from the stock shimming.
The gears are plastic and will break in, removing all the little imperfections on the teeth that make it seem tight. If you loosen up the gear mesh for when the gears are new, it will be too loose once you run the car and you will probably break gears.
Do trim away any flashing on the back side of the drive pinions.
kdub is offline
Old 11-06-2007, 09:18 AM
  #755
Jerry P's Avatar
Trader Rating: 44 (100%+)
I just took delivery of my b44 at work. I think i am coming down with something so i may have to leave early.
Jerry P is offline
Old 11-06-2007, 09:29 AM
  #756
Soupermike's Avatar
he's right, my front gears seemed way too tight but instead of removing the shims i let it go and ran a pack and right after that the gears smoothed out to a perfect mesh.
Old 11-06-2007, 09:50 AM
  #757
ryno529's Avatar
ok i will run it at the stock setting then and re check it after 2 packs
ryno529 is offline
Old 11-06-2007, 10:13 AM
  #758
Regional Moderator
mrrcguy's Avatar
Trader Rating: 25 (100%+)
Default B44
RC Hobbies in Jonesboro Ar now has a good stock of B44's.
mrrcguy is offline
Old 11-06-2007, 12:03 PM
  #759
rripp's Avatar
[QUOTE=t4ftracer;3834155]
Originally Posted by rripp
The whole team has been using no one way on the BJ4 for a year or so. If a one way is ever used, it is the center one. The front hd ntc3 one way is totally out of the question as far as I am concerned. It makes the car way too aggressive. The two diff, no one way set up is also better for brakes. You can drive deeper in to the corners and stop since all 4 wheels have brakes.QUOTE]
So I'm gonna hold off on the front one-way, but where can I get the center one?
No center available yet that I know of for the B44. I am still running the BJ4 for now and don't ever run a one way.
rripp is offline
Old 11-06-2007, 12:21 PM
  #760
How does a center 1 way work?How would the braking system work on a center 1 way?
bus driver is offline
Old 11-06-2007, 12:23 PM
  #761
magm20001's Avatar
you turn it down so it dont spin you out whne applying the brakes, works similar as a 2wd off power
magm20001 is offline
Old 11-06-2007, 12:47 PM
  #762
Drift_Buggy's Avatar
Trader Rating: 22 (100%+)
Can someone recommend a pinion to be used on a fairly large track with a Mamba 6900?
Drift_Buggy is offline
Old 11-06-2007, 01:37 PM
  #763
AssocRacer's Avatar
Mamba might have something on their website similar to Novak as far as gearing goes. They tell you the what the final drive should be close to on each class of car, so you can figure out your pinion/spur combo to get the recommended final drive ratio.
AssocRacer is offline
Old 11-06-2007, 06:20 PM
  #764
Shadows's Avatar
Trader Rating: 23 (100%+)
anybody else noticed all the trick alu (tower holders, castors and centre mounts etc etc ) and carbon parts (battery strap) already in the pending orders fr the B44?
Shadows is offline
Old 11-06-2007, 11:58 PM
  #765
What spur gear does it come with? I know the gear ratio is 2.5:1
