Like Tree495Likes
JConcepts Thread
Old 12-16-2008 | 11:39 AM
  #2371
Suspended
Thumbs up AE.......................IS THE KILLER OF ALL!
Yes your correcto..
losidriver70 is offline
Old 12-16-2008 | 11:41 AM
  #2372
dgullickson's Avatar
Originally Posted by BillySnarf
Alright, Santa is gettin me a few sets of tires from JC this year.. I just wanted to make sure/ or know if these tires on the sight some two to a pack? For instance, part no 3016 for 10.87.. that is for TWO bar code tires? correct?
Yep, 1 pair, or 2 tires. However you want to look at it...
dgullickson is offline
Old 12-16-2008 | 11:46 AM
  #2373
Thanks for the quick replies.. Just makin sure Santa didnt come up short this year!!
BillySnarf is offline
Old 12-16-2008 | 06:44 PM
  #2374
W.E.D.Jim's Avatar
Pair = 2
Set = 4
Wheel is the plastic part
Tire is the rubber
Rim is what is at the top of a toilet tank. hahaha
...Jim
W.E.D.
W.E.D.Jim is offline
Old 12-18-2008 | 04:05 PM
  #2375
J_P's Avatar
J_P
Great, this thread has gone to the crapper......lol
J_P is offline
Old 12-18-2008 | 09:06 PM
  #2376
rdub202's Avatar
...Jim
W.E.D.
haha, i always bust people's chops with that.
guy: "check out my new rims dogggg!"
me: "wow, did they come with new wheels too?"
guy: "huh?"
rdub202 is offline
Old 12-19-2008 | 09:07 AM
  #2377
Viking Racing's Avatar
Default Gold bar codes
The gold bar codes are dialed on pink taper tracks. I ran the golds front and rear in super stock; and pink x-2000, x-3000, and bk bars on the rear, and pink tapers on the front in modified. Usually we run pink tapers to slicks with wd-40; the track was a little wet. The ss 10.5 buggy was 11 seconds faster in the a-main which i won, and much more hooked up than any pink losi combination. I had a few bobbles in mod 8.5, and a second or two pulling over for the sponsored guys. I run a losi cr, and two of losi's best sponsored racers commented on how hooked up my buggy was.
The bar codes did not suddenly break loose in the rear like the losi, and was more consistent in the front. And the great thing is they last way longer. I would have used up a set of tapers and/or bk bars in each class. I can run these anohter week or two. The front foams are too soft i think, i used a stock losi foam which seemed about right. I'm going to try stock panther foams which are a little firmer than the losi next.
I haven't had a chance to wear them down to slicks yet, and the track hasn't called for slicks. We always use wd-40 on our pink losi tires, but i hear from a j concepts sponsored racer not to "sauce" the tires until they are about bald.
I hope this helps.
Viking Racing is offline
Old 12-19-2008 | 09:42 AM
  #2378
...Jim
W.E.D.
So what is a rim job then Jim?
And will you are at it, what would it mean to "play above the rim" in that sense of the word?
SirSpeedy is offline
Old 12-19-2008 | 10:14 AM
  #2379
Default Gold buggy tires
Where can I get gold front and rear 2.2 buggy tires? Please pm me.
uncle everett is offline
  #2380
Jason Ruona's Avatar
I hope this helps.
Thanks for the information.
Jason Ruona is offline
Old 12-19-2008 | 11:58 AM
  #2381
AndyMoore's Avatar
We've released the ‘Carvers’, a 1/10th truck front tire perfect for a variety of track surfaces. The sharp angular and directional ribs provide the ultimate in control and direction on the most common dry and wet condition surfaces, while the compact tire body combined with the JConcepts firm foam inserts allow for precise steering input and response for very consistent lap times. In new condition they excel on low traction surfaces as well as high “loamy” traction wet surfaces where no rubber has been taken into the racing surface. Worn versions excel on indoor or outdoor clay tracks where a light blue groove has formed. Available in sticky soft Blue compound and include firm foam inserts.
http://www.jconcepts.net/store/index...roducts_id=273
AndyMoore is offline
Old 12-19-2008 | 12:26 PM
  #2382
Jason Pelletier's Avatar
Those look like the proline tires that come with the t4.
Jason Pelletier is offline
Old 12-19-2008 | 12:30 PM
  #2383
AndyMoore's Avatar
The difference is in the details...
Old 12-19-2008 | 03:24 PM
  #2384
tschenck's Avatar
They do look very similar to the proline edge as you said. Looks like they added smaller ribs between the larger ones though.
tschenck is offline
Old 12-19-2008 | 06:18 PM
  #2385
AndyMoore's Avatar
Rib heights are different, along with spacing...and the added center ribs/dual single ribs.
