Kyosho Ultima RB5 Thread
#2422
Just an FYI...I just talked to Jeff at Speedtech and they got a Kyosho shipment in. They have some RB-5 bodies there...not checked in yet...but they're there, so you can place an order in a couple hours.
http://www.speedtechrc.com/store/ebp...id=556&id=6737
#2423
I'm gonna make a decision tonight, but I really do want to get those Ti screws for my car.
Thoughts:
I put the lipo in the car and dropped a few OZ out of the car like that and honestly felt like the car handled noticeably better. I realize that too much weight loss can lead to an poor handling car however if you can remove weight from something as simple as a screw and then add it somewhere else where that weight can be used as an effective tuning option....well then that's a win-win.
Thoughts:
#2424
Thoughts:
Thoughts:
and if the car is really light you just change your setup for it.
i think if you can find them mugen screws are cheaper than lunsford, well here anyways.
#2425
#2426
My fault for not saving the picture when I had it.....can someone re-post the picture of the 3 rear arms together? yall know what i'm talking about? the three rear arms side by side by side that shows the lengths.
if someone can post this, that would be great! i'll be sure to save it!
thanks!
thanks!
#2428
Thank you Casper!!!! I saved it this time! ya know....2mm is so negligible that I'm really thinking of going to the stock arms to try them. I have yet to try a short arm...it should make the car rotate better right? My track is CRAZY tight so a shorter rear width might make the car rotate better....am I on the right track?
#2429
I tried to mount up the bones/zx-5 hubs combo and it's no good, not with the middle arms, it "should" fit with the long arms, but I didn't like them when I tried them. You will need shorter bones, and you will need to grind a bit of the arm since the cup hits it at full droop.
