TLR 22 Front Arms Solution? >
Like Tree3Likes
  • 3 Post By ThisIsRDG
Old 04-14-2026 | 12:47 PM
Questions?? TLR 22 Front Arms Solution?
Hello everyone - hoping you can help me. I have a TLR 22 5.0 DC Elite and broke one of ym front arms. Horizon said they are discontinued and there is not a single set yo be found on ebay or any other board I have searched.
I was told that there are 2 options that could work with a little dremel work and some shims for the hinge.
1: Associated B6.4 front arms
2. Mugen MSB1 arms
has anyone had any success with these? or is there another solution? i head 22S arms but would lose the use of the sway bar...
Grundy454 is offline
Old 04-16-2026 | 12:27 AM
Jaygracie3's Avatar
Default Same problem
2. Mugen MSB1 arms
Im trying to find arms too
Jaygracie3 is offline
Old 04-16-2026 | 11:06 AM
wydopen's Avatar
Try to find a cheap 3.0 or 4.0 parts car or use the 22s arms and figure out a different way to mount swaybar. If you are running on a surface suitable for a front swaybar you would probably be better off upgrading to the 22x..Think the b6 arms would require the rest of the parts to get the track width correct. I have both cars, I can measure them if you need..
That said arms are cheap I'd buy the mugen arms and see if you can make it work..
wydopen is offline
Old 04-16-2026 | 12:21 PM
From Andrew Wilder on FB:
Losi 22 5.0 Mugen front arm mod
I recently broke my last left front A arm and parts are getting hard to find. I read on Facebook someone did this mod so for $16 I gave it a shot. The arms appear to be very similar dimensions and geometry. Hinge pins in relation to shock locations are virtually identical! You will lose a shock hole adjustment and a VLA settings, are the only downsides.
Drilled out inner hinges with an 9/64 bit. Outer hinge with a 3.5mm. add shims to space the shocks away from turn buckles. Suspension moves nice and free once adjusted.
warracer, HOTROD716 and wydopen like this.
ThisIsRDG is offline
