Like Tree77Likes
TLR 22X-4 2.0
Old 05-26-2026 | 07:18 PM
  #76
fifi's Avatar
Originally Posted by HOTROD716
The part number has been redesigned for the 2.0. The center section is longer than the elite version, accommodating for the 2.0 redesign of the sway bar mount.
I hope the one I will order will be the redesign version.
fifi is offline
Old 05-27-2026 | 06:22 AM
  #77
HOTROD716's Avatar
I ordered mine ultimatly from HH. Amain had old stock which did not work.
HOTROD716 is offline
Old 05-31-2026 | 03:07 PM
  #78
Running into an issue with the rear camber links rubbing on the rims. I did raise the the camber link on the tower one hole but I would assume you should be able to make that adjustment without rubbing? Anyone else run into this?
Sedizzle is offline
Old 05-31-2026 | 04:48 PM
  #79
Tiggertrucks's Avatar
I did, but i forgot to set the camber at -2 degrees
Tiggertrucks is offline
Old 06-01-2026 | 06:34 AM
  #80
HOTROD716's Avatar
You can either reduce shock shaft length to 28mm or what I did is to run AE ballstud with an AE turnbuckle for the outer. The AE one has a smaller profile.
Tiggertrucks likes this.
Old 06-03-2026 | 05:21 AM
  #81
Thank you, will give reducing shock length a go.
HOTROD716 likes this.
Sedizzle is offline
Old 06-03-2026 | 06:29 PM
  #82
PSA - If you remove the 2mm ball stud spacers on the rear hubs the stock 8mm ball stud is too long and will deform the hub and the larger inner bearing in the hub.... (DC version)
Losi may want to revisit some of the rear geometry or maybe the manual it seems.
Sedizzle is offline
Old 06-03-2026 | 08:32 PM
  #83
RazorRC's Avatar
Just curious, are you running TLR wheels? They're slightly different offset than other brands.
Horatio and Tiggertrucks like this.
RazorRC is offline
Old Yesterday | 05:24 AM
  #84
HOTROD716's Avatar
I thought I read or heard from Frank Root the offsets are IFMAR, no longer "TLR offset" .
wydopen likes this.
Old Yesterday | 09:39 AM
  #85
c666187's Avatar
TLR wheels for the 22x series vehicles are all now the same standard offset as AE.
wydopen likes this.
c666187 is offline
Old Yesterday | 08:47 PM
  #86
Correct, I am running the standard offset.
Sedizzle is offline
