Dynamite FUZE 160a blinking red light
![Questions??](https://www.rctech.net/forum/images/icons/icon15.gif)
so I got a used fuze 160 esc from ebay, I am using a spektrum smart firma 800kv motor, but there is no throttle. I have tried calibrating the throttle, but after setting neutral it blinks green once then does nothing else, even if I'm going full throttle then press set, it does not blink any lights or anything. I would like to know if this issue is fixable or if I should return it. it did not come with a manual, so if anyone can send over a copy of one that would be greatly appreciated!
![Default](https://www.rctech.net/forum/images/icons/icon1.gif)
is that the real dynamite website? it seems a little fishy, isn't horizon hobby their website? at least that's what pops up when I type the website on the box (dynamiterc.com redirects to horizon hobby)
I am using a flysky receiver, I just ordered a spektrum firma esc, if there are any issues I will consider this, thank you!
If you're using one of the cheap Flysky radios (FSGT3B or C), try changing the throttle trim up or down like +/- 10. The trim is screwed up on those IME, it might calibrate after doing so.
