Team Associated B7 and B7D
#1516
![Default](https://www.rctech.net/forum/images/icons/icon1.gif)
The front wing brace that is flush mount with flat head screws is by Vision Racing.
The front wing button that matches the style of the Factory Team rear wing brace is by Avid.
I started a thread for Slipper and Slipper Eliminator comparisons a while back. The thread has the weights of several options for comparison. I like the Schelle / Avid slipper. It weighs darn near close to a slipper eliminator but retains the smoothness.
#1517
I like the slipper in 17.5. If you run a class like 21.5, I would run an eliminator. It is a matter of power and accelerating. Slipper = smoother. Eliminator can be less rotating mass (as part of a complicated list of things).
#1518
There was a post a few pages back with data on runs comparing the two transmissions. The R1 Wurks transmission was faster.
R1 Wurks also has an interesting motor plate with top mount to distribute the motor weight better. Team Brood claims the kit design motor plate deforms the transmission case causing premature wear and failure. Team Brood has a transmission brace.
#1519
I ever encountered "jumped pinion gear teeth".
I used 25 teeth pinion gear, with 78 teeth spur gear.
I heard loud teeth grinding sound, when throttle buggy to take jump....ended up the spur gear teeth slanted slightly.
Thereafter changed spur gear to 75 teeth, pinion gear to 23 teeth, no more issue
#1522
https://teambrood.net/product/b7-cf-...ion-brace-kit/
Introducing the Team Brood Carbon Fiber Transmission Brace Kit, specially designed for the Team Associated B7 2wd offroad buggy. Engineered to address a common issue arising from the increased size of the motor plate to 5mm, this innovative kit is your solution to excessive flex on the left side of the transmission.
#1523
#1524
Team Brood need to upload product photos, so that customers will know how the product look like
#1525
Had a chance to run the new Schumacher Splinter ftom tyres on my local high grip astro track yesterday. I tried thr Axium in purple to start with which had too much grip and were a bit snatchy, the Splinters were really smooth and just the correct amount of front end without any major changes.
I also tried a tip ftom Ellis Stafford to lengthen the rear camber link at the inboard end so that the camber link and wishbone pivot lined up. This helped to get rid of the rear wanting to continue to rotate before getting back on the throttle - really gave confidents about what the car was going to do.
I also heard some of the uk team drivers were using b6.4 front hubs (so removing the kpi). Somebody was running them and mentioned it made it a little pushy mid corner compared to the standard b7 setup.
#1526
#1527
The Axium silver is a better compound for the dry but they do have more grip I find than the LP Cut Stagger Yellow but I like the fact they they fit the wheel properly without having to glue sides down but I feel you have to change the setup at the front and you cannot just change between Axium and Cut Staggers without adjusting the setup. I have yet to try the Splinter but have high hopes. Did you run an insert or no inserts?
I previously used Axium in Silver but couldn't get them for Monday. I have found that raising the ftont axle helps tame the axiums.
#1528
![](https://cimg2.ibsrv.net/gimg/www.rctech.net-vbulletin/696x288/img_20240529_wa0032_0e24b511d8a1b16c61b3e9c982ed787d46ac6378.jpg)
More gears, acceleration decreases.
Many B7 players run 17.5 turn motor, realised it accelerates slower than 3-gear transmission
#1529
#1530
