Schumacher cougar LD3
#361
![Default](https://www.rctech.net/forum/images/icons/icon1.gif)
Like Rhett had said, the only clearance issue for me too was the steering rack. I still use the plastic rack and plastic swing arms, so material had to be removed to allow properly smooth operation.
Rhett, which Schumacher ballstuds did you actually use on your car, and looks like Avid shims.
U8500 Ti Ball stud long U7824 Ti Pivot ball high at front camber mount
U8453 Ti ball stud short
Ball stud washers are Jconcepts 8111
#362
Can someone explain in real world terms the handling difference I would see between the regular springs vs the high response springs? I understand the less coils and thinner wire of the high response springs but how are two springs of the same rating different on the track?
#363
#364
R/C Tech Elite Member
#365
#367
ChocoTaco73 Do you know if the normal or high response springs come in the kit?
#368
[QUOTE=staiguy;16100127]ChocoTaco73 Do you know if the normal or high response springs come in the kit?[/QUOTE
I stand corrected, High response Black front and High Response Green rear springs are in my LD3D kits
#371
Back to the topic of turnbuckles, found these AVIDs. Most interesting thing is no bend/break guarantee.
![](https://cimg2.ibsrv.net/gimg/www.rctech.net-vbulletin/1270x186/screen_shot_2024_05_14_at_9_43_28_am_d774009a490163c2d5d1c48b538b5af178bc60a9.png)
#373
Are there any alternative slipper eliminators/lockouts that work with the schumacher lockout topshaft? I'd like to be able to use more common spur gears like kimbrough, exotek, etc. that use 3 screws to hold them on rather than being restricted to just the schumacher spur gears that use the 4 pins for drive. I've tried a couple others but they haven't worked, seems like the schumacher shaft is slightly too big for the other slipper eliminators I've tried.
#374
#375
![](https://cimg8.ibsrv.net/gimg/www.rctech.net-vbulletin/410x421/ld3_spur_adapter_b16b5d5c2a71b6c20d2894b5b458d7360e67594b.png)
