Tekno RC SCT410 2.0
#16
I hope the nose dive issue is better than the previous offerings. I tried all the different fixes with no luck, changed driving style still no luck. No matter what Im ordering it! Tekno R/C SCT are rock solid just have minor issues!
#17
Matt
Any chance of getting servo recomendations on this new truck before the release date next week?
#18
#20
^Dang. I'm not a fan because of tool access to the motor screws.
#21
Sir 51D3WAYS, I knew I was gonna see some feedback once I posted that picture of the motor mount. I'm sure there will be an option for a two piece. If it means running the single piece mount to be able to use the gear cover, then I'm all for it. "The pain" only last for a few moments until you get the correct gearing. Who knows? Maybe the access to the screws is not as bad as it seems..
#23
I am not sure about those shocks! 13mm is awfully small for a tank like this thing looks! Plus the 16mm spring option sounds like a pain to deal with!
#24
Will 16mm shocks fit as an alternative?
If the shocks are closer to the 85mm and 103mm lengths, will a short (meaning ~85mm) shock be available?
Will TKR6142 be the part number for a short version of TKR6143?
Hopefully the manual will answer some of these questions.
#25
IDK! I wish they would at least put the manuel on line so we can start getting an idea what we are looking at. I have mine pre ordered so we shall see.
#27
I don’t think 13mm shocks will be a problem. The TLR uses 12mm and the worst part of that setup was the springs. In this case, Tekno put big boy springs on and have a little more body. If the class was active where I live, I’d order one of these ASAP and swap the electronics over from my worn out TLR.
#28
Shouldn't be pre ordered, my local hobby shop has a couple in stock right now, i ordered mine from amain said in stock
