5Likes
Super Glue for tires
Need to glue up tires and unable to get to hobby shop in time. Assume I can use regular CA super glue from WalMart or hardware store. Recommendations on which works best?
Anything Loctite brand should be good. I have "professional liquid" on my desk right now and use it interchangeably with rc brand glues on tires. I prefer it on shock towers vs my AKA glue since it dries nice and clear.
It will work but isn't quite the best. The rc tire CA glue usually holds up to flexing better than regular CA glue. After a while of abuse, the glue may separate, may not. For bashing its fine, but if it were for racing, I'd wait
Thick ca is the best.
+1 for LOCTITE Professional which is a medium thickness and works well with 18GA glue tips
Many drivers in my area have recently switched to LOCTITE 406 which is a specially formulated to bond rubber to plastic but it's a thinner product and better used with 20GA tips:
https://www.amazon.com/gp/product/B07PZKQG3Y
https://www.amazon.com/Genuine-Henke.../dp/B072Q7CFYS
I recently got a bottle of 406 and it has a marked Mfg Date of 14-OCT-22 and Exp Date of 7-JAN-24
I now make it a point to shake the bottle to see how viscous the glue is before I buy it
I'd use loctite professional if I couldn't get to a store. It was recommended to me by an AE team driver.
However, if I can, I always and only use proline tire glue. I've had issues with a few others and once glue fails it's all over. Carpet places a lot of stress on the glue beads. Other types or surfaces may not.
I have been using cheap supermarket superglue for years.
It's the same thing, CA = Cyanoacrylate = Superglue.
The difference however is definitely in the viscosity of the glue (thickness) but I still find the supermarket stuff usable.
I have used Gorilla brand CA with success to glue tires, both on and off road. Usually holds up very well. But then I think that cleaning the tire bead and rim correctly is probably more important than the glue brand you use.
Martin Paradis
Martin Paradis
I’ve been using trade spec superglue for years, way cheaper and works perfectly.
Wondow fitters (double glazing, where they glue the trims on after fitting frame) use different viscosity of glue in different temperatures.
Find any window fitting or decent hardware store and choose your preferred thickness.
I always go medium, hate the thin ‘pro’ stuff, just end up with glue everywhere 🤷♂️😂
Depending on what's available, ZAP CA, Bob Smith and even 3M Scotch brand (blue cap) have worked well IME.
