4Likes
Setup sheets
Petit R/C is a good source for setup sheets
Also RC10.com
Both have setup sheets and trouble shooting info and or setup help sheets.
https://site.petitrc.com/setup/associated/setupb6.1/
https://www.associatedelectrics.com/
Most manufacturers have a dedicated documentation section on the webpage for the kit on their website. That page usually contains things such as manuals, blank set up sheets, and complete set ups from their factory drivers for specific events they have run.
If you can get us the make and model of your car, we can point you right to the source.
Looks like you may have picked up a B6.4 ...
I'd say Team Associated's site should have some starting setups as well as Petitrc, those would be the 2 places I would start my search for first.
Good catch, Cain. I didnt even think to go look at his post history, LOL!
https://www.associatedelectrics.com/...anuals_setups/
Brent's setups are always a good place to start. He likes a neutral set up that works for most.
You guys are correct. I bought a B6.4 kit and built it according to the specs in the manual and did add several upgrade parts. There is so many tuning options with this buggy that I don’t even know where to start so I figured I would try to find some setup sheets to check out for tips. There’s 2 tracks here that I plan to race at, both carpet but one is a large track and the other is a smaller track so I’d like to start learning how to adjust things as I go.
Got links to the tracks you are going to, be curious to see your tracks. Biggest thing I am seeing being played with on the AE cars with the 13mm shocks has been the piston selections, with some drilling 2 extra 1.1mm holes on the stock piston sizes or going with bigger pistons on the car.
I'm running a high grip but smaller track, some of the jumps make us land almost flat.
FRONT: 1.6mm x 2 hole 400cst, Yellow 13mm front springs
REAR: 1.8mm x 2 hole 325 - 350cst Yellow 13mm rear springs
Or this:
FRONT: 1.5mm x 2 hole with 2 1.1mm holes drilled, Yellow 13mm front springs,
REAR: 1.6mm x 2 hole with 2 1.1mm holes drilled, Yellow 13mm rear springs
For me, I am trying out the 13mm AE shocks on my Yokomo CAL3.1 here and will be trying this:
FRONT: 1.6mm x 2 hole 400cst, Yellow 12mm V2 front springs
REAR: 1.8mm x 2 hole 350cst Yellow 12mm V2 rear springs
Going with these springs as that would fit with what I was using on the Yokomo shocks so I can better isolate what the body change did I am thinking. To do this, you need to flip the adjustment nut on the shock and use 12mm lower cups, AE ones fit best on AE shock eyelet ends.
Front: 1.7mm x 2 hole piston 35wt oil with orange springs
Rear: 1.8mm x 2 hole piston 32.5wt oil with yellow springs
Here is one of the tracks
https://youtu.be/wLp9mhhJUpw
and here is the other one
https://youtu.be/ofuFj4S2YGw
The first one is a small track black carpet and the other one is a larger track.
