Schumacher CAT L1R
#121
I was wondering what went wrong, was hoping that its not a problem with the gears being soft.
Originally was wounding if i had the shims correct ont the rearend gears or if the o-ring on the rear diff was not tighten down anofe to smash o-ring making the gears have to much play, but i found a screw behind the spur gear backed out and was stopping the spur gear so on power probably stressed the rearend diff gears.
#122
#123
I really appreciate your help , ill start checking mine as well, thank you
#124
What is the character difference between the carbon fiber chassis versus stock aluminum ?
#125
The following Trishbits YouTube videos feature the CAT L1 Evo but should be helpful for the CAT L1R.
Schumacher CAT L1 Evo Driveline | Tips and Tricks
https://www.youtube.com/watch?v=LDtQElx5XH4
RC CAR 4WD SETUP! |TIPS AND TRICKS | PART 1
https://www.youtube.com/watch?v=sUYpi_jqp0Y
RC CAR 4WD SETUP | TIPS AND TRICKS | PART 2
https://www.youtube.com/watch?v=KLqAJ80Z6l8
#126
The current VTD is surely more tuned for the aluminum chassis. (If) When Schumacher releases tuning options for the graphite chassis - that should be a solid solution for the L1R.
#127
Thanks for the info on chassis, which one flex more , would you say ?
#129
for people running this car in the states , how is parts availability? I know my local hobby shop does not carry it and Amain seems to have a lot of backorder parts...
#130
DiscountRC has many of the parts available.
#132
#133
#134
Schumacher seems to be gaining a lot of traction (excuse the pun) here in the U.S.!
#135
I feel they are making headways again. In the 80's and 90's many in WNY were running the CAT at the tracks, it was a great, but complicated car. I still have my Schumacher 1/12th scale pan car from the late 80's! I feel the company has lost its's way in the late 90's 2000's in the US. Now with the new products coming out, and with signing some US drivers, I see the brand making a decent comeback .I can say from my point of view, I am faster and more consistent with the L1R than I have been with the Shaft driven cars. The LD2 I am using now I am starting to feel more comfortable with it, making some progress, into the A's with it.
