Schumacher CAT L1R >
Schumacher CAT L1R
Like Tree96Likes
Schumacher CAT L1R
Old 12-16-2022, 05:44 AM
Default Schumacher CAT L1R
The Schumacher CAT L1R brings all the latest developments from the Schumacher International Racing Team, to make another sensational 4WD buggy. A buggy that can take you to the top of the podium. The L1R features improved suspension geometry, lighter weight, better durability, and a new JConcepts bodyshell. The L1 series of buggies have already won the European EOS championship, British BRCA national championship, and the USA ROAR carpet nationals. The L1R is an awesome looking buggy that is sure to be a winner on all types of track.
  • New - Front hub carriers with screw on steering plates, allows adjustability to suit all track conditions.
  • New – Layshaft and slipper plates with M4 layshaft Nut. Lightweight, twin pad slipper clutch with Ultra Fine adjustment spring. The new drive interface for the plates and gears allows more true/concentric running and improves the efficiency.
  • New – Rear suspension geometry for more stability and improved rear traction. This new geometry keeps the car flatter in the turn while maintaining its grip through the corner.
  • New – Wider suspension mounts.
  • New - Rear hub carrier with larger outer hub bearings and multi positional camber settings. 10 camber link positions on one plate with shims to adjust the vertical height.
  • New – Longer rear U/J steel driveshafts.
  • New – Rear camber strap.
  • New - Hard anodised -1.5mm width, 12mm wheel hex.
  • New – Suspension pivots inserts for more accuracy and durability. Steel top hat bushes for longer lasting pivots and a greater span for the bearing area of the effective hinge pin length.
  • New – JConcepts bodyshell design. Popular well known style which offers a great balance of steering and stability.
  • New – Shorter front U/J driveshafts. More forward drive and reactiveness.
  • New - Longer front diff outputs.
  • New – Stronger front upper transmission housings.
  • New – Updated front wishbones.
  • New – Steering ball cup and 5.5mm ballstuds.
  • New – Front inner 3.5mm hingepin with raised position. For more forward drive and agility.
  • New – Low CofG pinned and centre mounted motor mount. That allows full height shorty lipos to fit in the new forward mounting position. The Lipo position is 9mm further forwards than the previous model.
  • New - Hard anodised 2mm 7075-T6 alloy chassis. Pocketed for easy radio access with S2 removable trays. Sleak new shape to the rear of the light weight and flexible chassis which allows the car to transfer weight to the rear through corners without the chassis catching the track.
  • New - Moulded composite side pods. Allowing the flex to remain with these soft high quality moulding
  • New – Easy access LiPo mounting with further forward positioning.
  • New - 3 piece top decks.
  • New – Longer rear shock shaft.
  • New – Rear 1.8mm Anti-roll bar to match the new geometry, included.
  • New – Gear diff pulley housing with thicker planetary gear shim for better durability. Improved efficiency of the diff in the run.
  • New – Moulded shock pistons and bushes.
  • New - ‘S2’ shock brackets. To suit the new front and rear geometry's
https://www.racing-cars.com/cat-l1r-kit-k201
trx-1racer, LOW ET, 305M3 and 2 others like this.
ChadoSan is offline
Old 12-16-2022, 06:02 AM
LOW ET's Avatar
Trader Rating: 109 (100%+)
been waiting to see their new kit and now it's here.
LOW ET is offline
Old 12-16-2022, 07:25 PM
RazorRC's Avatar
Looks awesome, the new body is a huge improvement if nothing else.
RazorRC is offline
Old 12-16-2022, 07:29 PM
I didn't know anyone still did belts for 1/10th offroad buggies: looks cool!
PetRock is offline
Old 12-19-2022, 01:52 PM
ZEe_NYC likes this.
ChadoSan is offline
Old 12-20-2022, 02:38 PM
warracer's Avatar
Man I love belt driven buggies, I just wish you could run one of these on dirt or clay.
Sure you ''can''' but open belts are just a ton of maintenance compared to a sealed system.
warracer is offline
Old 12-20-2022, 02:54 PM
R/C Tech Elite Member
ChocoTaco73's Avatar
On loamy dirt maybe but not on clay. After a day of racing just give the pulleys a look, if there is some dirt in between the teeth, clean it off. If not, carry on.
warracer likes this.
ChocoTaco73 is offline
Old 12-23-2022, 04:05 PM
ChadoSan is offline
Old 12-24-2022, 07:47 AM
Was gonna hold off but ended up pre-ordering the L1R. Merry Christmas to me!
Cain, LOW ET, RazorRC and 2 others like this.
Old 12-24-2022, 08:03 AM
Trader Rating: 19 (100%+)
It looks unique enough, I might need one.
hunterdawg is offline
Old 12-27-2022, 01:50 PM
Tech Legend
Cain's Avatar
Trader Rating: 294 (100%+)
Originally Posted by ChadoSan
Interesting the tires of choice on the rear wasn't the cactus. Front Fusions in general though are a very good tire.
Cain is offline
Old 12-27-2022, 08:15 PM
It would have been fuzz bite fronts too but they were out of 4wd fronts at the event.
Cain likes this.
ChadoSan is offline
Old 01-04-2023, 10:11 AM
Tech Legend
Cain's Avatar
Lee Martin to Schumacher ...
Cain is offline
Old 01-05-2023, 10:45 AM
And now Cavalieri, how next? Tebo?
Badger5 is offline
Old 01-05-2023, 11:59 AM
Tech Legend
Cain's Avatar
based on this release, is there a new 2wd buggy in the works as well?
Cain is offline
