Team Associated B74.2 / B74.2D >
Like Tree150Likes
Old 12-08-2022, 12:03 AM
  #91
I gotchu fam
https://img2.associatedelectrics.com...Parts-List.pdf
BigBuckORamma is offline
Old 12-11-2022, 08:27 AM
  #92
rob martin's Avatar
Trader Rating: 66 (100%+)
Originally Posted by RazorRC
If you’re running carpet, I suggest running the Dustin Evans PDX setup out of the box, don’t even bother with the kit setup, it’s 100x better.
https://youtu.be/UXubTf23F1Q
Just got done with my build. Did you follow Dustin's setup with his bumpsteer spacers on the steering rack? I got alot of bumpsteer with 2mm of washers under the rack
rob martin is offline
Old 12-12-2022, 01:56 PM
  #93
Yes LTC plastic is ASC92307 while HTC plastic is ASC92076 as I mentioned. They were specifically asking for HTC, hence my reply.
nesbot is offline
Old 12-14-2022, 07:38 AM
  #94
Tech Legend
Cain's Avatar
Trader Rating: 294 (100%+)
For you guys running on carpet, in general are you going with the new style 3 hole pistons? Seen those new Ray Munday charts for comparison of the 13mm pistons against the 12mm, very interesting.
Cain is offline
Old 12-19-2022, 05:38 AM
  #95
macnkitty2002's Avatar
I have an opportunity to buy a new, assembled B74.1D and was wondering if it was worth it given the value proposition or should I just get the .2 edition? Here is what I’m considering:
B74.1D
Body/wing
New/used Wheels/tires
He’s asking $325
Is this a good value or should I pass it over for the .2 version? I'm just looking to do some occasional club racing for fun, not trying to win any championships or anything. I race on a fairy large clay 1/8 style outdoor track. Also worried that the 74.1 is now ~2 years old at this point and parts may be harder to come by sooner than the .2?
macnkitty2002 is offline
Old 12-19-2022, 05:56 AM
  #96
Tech Legend
Cain's Avatar
Originally Posted by macnkitty2002
I have an opportunity to buy a new, assembled ARTR B74.1D and was wondering if it was worth it given the value proposition or should I just get the .2 edition? Here is what I’m considering:
ARTR B74.1D
Body/wing
New Reds 6.5t motor
New Hw10 pro esc
New nitro pro servo
Used 21.5 motor
Multiple pinion sizes
He’s asking $500 OBO
I'd almost wonder if you would benefit from the larger shocks on a track like that at a minimum.
Cain is offline
Old 12-20-2022, 11:29 AM
  #97
racerx128's Avatar
Question does anyone have a good setup for a medium sized hard-packed outdoor dirt track that has low to med traction run wet with bumps?
racerx128 is offline
Old 12-23-2022, 10:23 AM
  #98
Just picked up a b74.2 after a 10 year hiatus from the hobby. I can't wait to get back onto the track.
Things have changed drastically.
Kraig and Lordzod like this.
edman4523 is offline
Old 12-26-2022, 09:02 AM
  #99
Lordzod's Avatar
Thumbs up Good luck
Hi edman, good luck , I pre-ordered mine in September and did my build also at the end of the same months. The only problem I had in the build is sanding and reaming the arms , The car feels amazing ( I still own a B64D that I still love)
I run in the MOD class , What class and what kind of tracks do you have nearby .
B74.2D new Build
B74.2D with Body
Lordzod is offline
Old 12-28-2022, 11:54 PM
  #100
Running indoor carpet on a med size track. What size pinion for a 13.5 motor? Or at least a range.
Old 12-29-2022, 05:39 AM
  #101
23-25 should cover what ever motor you are running.
mbrienzo is offline
Old 12-30-2022, 12:57 PM
  #102
No spot for an antenna mount? anyone.....
Old 12-31-2022, 07:28 AM
  #103
Hey Guys! I have a 74.2 car, and I would like to run on a dirt track. Dose it really hurt the car ?
andrasferencz is offline
Old 01-06-2023, 01:55 PM
  #104
Trader Rating: 17 (100%+)
No issues, but adding some of the parts from the dirt car, specifically the springs/oils, sway bars, and center diff, will make it handle the dirt much better.
MrLean is offline
Old 01-06-2023, 01:56 PM
  #105
Having traction roll issues on carpet, specifically at the end of the corners, any remedies? Running 11mm ride heights, pretty much kit setup otherwise. Fuzz bite rears and either swagger or fuzz bite fronts, doesn't matter.
MrLean is offline
