Team Associated B74.2 / B74.2D
#47
I had to sand down the hinge pin spacers on 3 of the arms to get them to move freely.
#48
hi all,
Does B74.2/B74.2D faces the below video issue ?
#49
All the comments on the arms... ya Rivkin covered this in his YouTube video. They need to be reamed and if they are still tight then sand the shims until they don't bind and fall under their own weight.
#50
#52
#53
I bought the .2 front arms and tower and put them on my .1 with the used shims. Fit absolutely perfectly.
#54
I used to run the plastic gears on my 74.1 in 13.5 on Astro with a slipper and only had an issue once in 2 years - I had the back of the big gear, where the pin goes, strip once.
Recently installed the LCG plastic gears. Held up the entire race day on Astro, but the teeth started chipping almost immediately at our first carpet day.
Going to try the LCG metal gears with 2-gear setup.
I was on 20k/15k with plastic 4-gear setup. Should I adjust oil with the 2-gear metal setup?
#55
So just finished my b74.2 had a sf2 and Xray before taking a break from 4wd now ..I had a small issue with the noise from the car it turned out the slipper needed to be done a little tighter so glad…and been email to ae from the uk and replied straight away so glad I left my previous sponsor to go back to be a privateer with a shop deal…
#56
If you’re running carpet, I suggest running the Dustin Evans PDX setup out of the box, don’t even bother with the kit setup, it’s 100x better.
#57
I feel the same way about Dustin Evan's Hobbyplex setup being far better than the kit setup for indoor clay for my B6.4D. It made a world of a difference for my car at my local track.
https://site.petitrc.com/setup/assoc...yplex20220710/
#58
https://youtu.be/UXubTf23F1Q
https://img2.associatedelectrics.com...ast_Carpet.pdf
#59
Is that pill setup correct, or is it supposed to be the opposite? Wouldn’t this give 5* of toe-in?
#60
Hi folks, apologies but I can't find a definitive answer as to whether the .2 gearboxes will fit a .1 chassis...it is suspected not but has it been confirmed?
Cheers, Paul
Cheers, Paul
