Team Associated B74.2 / B74.2D
#32
I don’t know about the dirt car, but the kit carpet setup seems really off to me.
#33
I put in the LTC gears and gullwing front arms and tower on my .1. Also started with 15k F and 10k R oils and it felt great with them. They feel a little looser and don't bind as much under load (cornering) so you run slightly thicker oils.
The new gullwing stuff in the front is great. Softens the initial steering a bit even on slicks and high grip.
#34
Got a chance to run my B74.2D on med grip clay this past week and gotta say, the 13mm shocks were super plush on flat landings and kept me for getting squirrely and allowed me to accelerate away more often that not. I ran 2x1.7F and 2x1.8R with 32.5/27.5 and stock springs. It was a cool evening so I can see going up 2.5-5wt when summer returns. The LTC gears are amazingly smooth vs the older gears, I had plastic in my .1 as well and it is night and day difference. I ran 10-350-7 and it went really well but might consider moving up like others have mentioned to 15-350-10. The only issue I had was the shimming of the diffs, whoa they were tight. A 0.25 shim on each side of the diff resulted in a screaming noise I thought I had the wrong pitch spur lol. Anyhow, removed one shim from the bevel gear side and that helped immensely. It still had a bit of a scream down the back straight, so I finished the club race and once home pulled both doffs out and placed both 0.25 shims on the diff case side because I think the bevel gear on the diff and the centre pinion gear were just too tightly meshed together. This was an issue with my .1 as well so I hope I have it solved. Last item, the new .2 came with plastic "blocks" which keep the top and bottom of the front spindles apart. I assume this is due to the plastics cooling and shrinking to where they are too tight for the aluminum caster blocks to fit freely and then need to be sanded as per that video Spencer Rivkin did talking about ensuring the front end is free for those who remember. Anyhow, great kit, love the new shocks and gear sets.
#36
They are closer in design to the B5 ballcups than the B6 based ones.
#37
Did a quick search but couldn't find anything on my specific question. Building my first center diff and I must be doing something majorly wrong, because there's no way I'm getting enough diff fluid in the cup to make weight. The fluid is already overflowing and it is 4.5g short. I've let it sit overnight and spun the gears a bit to make sure there are no air bubbles.
Am I supposed to include the spur gear and spur gear screws when weighing?
#39
#40
I dont build to weight, no time for that at the track. I just make sure its full to the top including the sun gear and then assemble.
#41
Gear diff build,.finger wipe
I don't use a scale when building my gear diffs. Some use their finger, I just use a driver across the top to wipe the excess.
https://fb.watch/g3PTJ3jhsX/
#42
#43
I haven't gotten the B74.2 yet, but we ran our 13.5 B74.1's on indoor astro with plastic LTC gears, 20k/15k oils and a center slipper at our trophy race over the weekend and it worked well...I was BQ (car shut off while in 1st halfway through B-main), and my son qualified 4th and finished 1st
#45
I did notice the arms are very sticky on the hinge pins, making ride height adjustments inconsistent, even after using Arrowmax reamers. I've got some actual 4-flute reamers on the way from McMaster I hope will alleviate the issue. edit/update, they didn’t need any reaming, the spacers were too tight and causing binding.
