Team Associated B74.2 / B74.2D
#136
Does the 74.2 have the same transmission ratio as the 74.1? I want to use this calculator but want to make sure my numbers will be valid since they only have the option for the 74.1 listed.
https://apps.associatedelectrics.com...fdr/index.html
Edited: Ah...I forgot about the LTC gears...not sure what difference they make!!! *smh*
#137
Thanks. That was actually a very big difference
#139
Finally got this car much easier to drive on black carpet. Biggest change I made was mounting the front shocks outside/outside and going to the new wider AE front wheels. Orange/Yellow springs with 2.5mm 2x1.7/2x1.8 pistons f/r, 37.5/32.5 oil. Might be TOO locked in at this point for some, but worth a shot if you're feeling twitchy. Cheers!
#141
Does anyone test the thre hole pistons in the B74.2?
I alway saw setup with the standard two holes pistons 2mm or 2.5mm.
#143
The only punch you could gain from gears would be going from metal to plastic. HTC to LTC is handling differences. At least as far as my understanding of how things work. Theres only 2 things changing, gear mesh/bind and metal vs plastic weight. Gear mesh/bind wouldnt change punch/accel only how the diffs react in corners. So its just weight.
You can find LTC and HTC gears easy enough by looking through AEs website. HTC come in the kit, so they are the plastic gears that have been available for years. LTC is the new stuff.
Maybe this explains the punch difference-
The LTC are so smooth in the center diff that to get an equivalent to 200k-500k HTC you would have to run 1m LTC. It's much easier to rebuild diffs with 200-500 than over 1m, that's why some guys stick with the old gears in the center. The LTC can bleed out power to the front wheels, atleast that's what I've understood from other drivers.
#144
A couple fast guys at the carpet track are running 15k diff fluid in the front and 20k in the rear. What's the advantage to running a thicker fluid in the rear?
#146
Any feedback on the new steering plates?
#147
Anyone know where to get the newly released FT Ring and Pinion Gear Set, molded ASC92318? Its on backorder everywhere I look.
#148
Anyone have a solution for shock cups lifting? The car was driving funny and noticed the shock cup lifted and wedged in the spring. All of them slide up with no resistance. I even checked the spares from the kit. They are all loose with no resistance holding them down. Normally you must wedge it down and it holds.
#149
#150
They are not hitting the arms. The spares in the kit are just as loose.
