Associated 12mm shock springs >
Old 09-07-2021 | 02:14 PM
Default Associated 12mm shock springs
this replaces my first post whihc I messed up
here is a chart of all the AE 12mm shock V-1 and V-2 spings
File Type: pdf
Drbrake is offline
Old 09-07-2021 | 02:50 PM
So what does decimal number in the last column for the V2 springs (Delta?) represent? ...
tomkatn is offline
Old 09-08-2021 | 09:54 AM
c0sie's Avatar
The difference in spring rate for the given colour across V1 and V2.
c0sie is offline
Old 09-08-2021 | 02:28 PM
Thanks, I guess I kind of saw that reading across, but didn't think it would be that simple or a need to include it in a chart that showed ratings of each version already ...
tomkatn is offline
Old 09-08-2021 | 02:31 PM
Pistol123's Avatar
I think you have a mistake on the rear springs, initial glance looks like you are off on the rear v1 for blue and yellow. I usedvthis from a mate when the v2 first came out.
Pistol123 is offline
Old 09-08-2021 | 05:03 PM
The 91339 61mm V1 was in error, should be 2.30lb/in, the yellow is correct at 2.40 ... with that said, the factory spring ratings should be used as a 'reference' with a bit of a grain of salt, it is not uncommon for variances from said ratings, sometimes significantly .. I have tested hundreds of springs (both new and used) and many came in heavier/lighter than the rating, sometimes they were off more than the color on either side, especially on those with a rating separation of only .10 lb/in from factory ... then run them for a few weeks, test again, and you may have even a new set of #'s ...
Edit to add: ... The V1's did seem to more often have a variance than the V2 however, of those I have tested ....
tomkatn is offline
