Tapping plastic during build
#16
I disagree with this if you're talking about the strength of the threads in the plastic holding the fastener in the hole. This is because sometimes self-tapping the screw leaves a worm of plastic that comes out when a screw is removed, or can get mashed into the threads in the plastic if removing and replacing the screw. This doesn't happen or matter enough for me to bother with using a tap set, but I think this does weaken threads in plastic where it happens. Generally less material meaning less strength, but mashed up threads are threads with less material doing its job.
#18
I've had to drill out too many stripped heads of titanium and aluminum screws on used vehicles, where someone threaded the screw directly into Associated 'hard' plastic without any prep work ... if the application warrants it, tap the hole as a precaution ...
#19
I wouldn't tap. When you tap you remove material, and the screw will probably come lose.
The principle that is use on RC cars is that the screw forms the thread, moving the material towards it, therefore making the plastic "hold" the screw. The same principle is use in machining, its called roll tapping. The hole size is bigger than on a cut tap, what roll tapping does is it "rolls" the material towards the tap, forming the thread, not cutting it.
#20
I tapped the holes on one kit and will never do it ever again, every screw that was tapped started to back out on it's own. I would have to check every screw after each run and re tighten them. Then I used thread lock and that helped a bit. Also the threaded holes stripped out easier because of the constant retightening. Maybe tap to get the holes started, but not all the way.
#22
I have never used a tap on any plastic mainly because I didn't think it was necessary. After reading the posts here, especially the one from the fella who did use a tap and the screws kept coming loose, I realize just what a bad idea it would be. Spinning a tap in for the first couple of threads or so would be a good compromise I think but only if it was extremely hard to get the screw started in extremely hard plastic
#23
No argument here. When I'm assembling a part that uses more than one screw I'll turn one screw in two or three turns and switch to the other screws and back again until they're all tight. Gives my wrist a little bit of a break between screws. On a slightly different topic, what are your guys opinions of disassembling to put in Ti screws after initial assembly was complete. My opinion is taking screws out and putting new ones in probably doesn't have enough effect to decrease the hold of the screw but I also think nothing would be as good as the first time the screw goes into the plastic. Opinions?
#24
#25
I haven't had an issue with it. They go back in pretty easy.
I'm referring to taping it with the original screw before inserting a Ti-screw. I would not tap plastic with a tap. I would, however, tap that... never mind.
#26
never pre-tap plastic its designed to be used without tapping.
#27
I'll start threads with a tap, just to make sure everything starts straight. Then I'll use a screw with some grease in it.
#28
Where possible, I try to put the same screw back into the hole it came out of. Not practical in a pit/race environment, obviously, but is doable on the workbench.
Oops. Dinner's ready. Gotta go. Cheers. 'AC'
