Team Associated B74.1
#287
What turnbuckles are those?
#288
Fix shocks upgrade
Just boughvthd fix shocked and machined pistons . Do yiu guys use the black pinterbsl parts for the shocks or The white ones .
#292
What spares/parts are interchangeable with the B6.2 from the B74.1?
shocks/shock internals, ball cups, turnbuckles, rear wheels, arms, etc?
#293
Pills too, but also full shock bodies/shafts if you are using kit 74.1 shocks and not the long bodies on some pro setups.
Oh and rear hub inserts, and all the other hub parts. Most bearings, hexs and lots of other stuff like that.
#294
Shocks and pills are the same
what about ball cups, turnbuckles, rear wheels, arms, etc?
#295
Edit: big derp mode, thought you were discussing b74 to b74
#296
Rear arms are kind of interchangeable. Hinge pin to hinge pin is the same, but the shock has more droop where it mounts on 4w arms and the .1 arms have an extra inner hole. Sway bar mounts are slightly off but compatible.
Not a tons of parts are interchangeable but lots of little parts are. Whats your goal here?
#297
#298
All the stuff you and I listed except turnbuckles aren't as most/all of them are shorter on the 4w.
the idea of stocking another bunch of parts and an additional small parts bin for another vehicle wearies me (I am the team mechanic and sponsor)
i was hoping there would be more crossover in parts between the AE 2&4wd buggies
my local track doesn’t stock AE or Losi parts so I either have a spare, or that car is done until parts arrive by mail
doesnt seem like much, but it adds up.
#299
i drag 5 vehicles and radios(so everyone can drive any car without rebinding) and 2 chargers, tools, fans, batts, snacks and lunch, soldering iron, and parts for each track day (4-5 drivers in family)-
Better off just getting everyone running the same exact buggy/truck, so yeah good luck with that lol. Really weird your local track doesn't have parts though.
