Tekno EB410.2 Thread
#272
I've heard the claim that mounting the transponder on the chassis causes problems? But it has not happened to me. Another location to mount it, is double-sided tape to the Servo. Towards the front of the car, but behind the plastic guard the body velcro to. Be careful the wire does not touch the drive shaft. Either run the wire under the chassis stiffener, or use a little tie strap at the bottom of the chassis stiffener, when you go around the front.
#273
#277
For my eb410.2, picked up a TKR6553X - Adjustable Ackermann Spindles and TKR6669A - Spindle Arms Type A. It rubbed bad. +1 Hex, AE b64/b74 front rims. Went to a ball that was lower to the the Spindle arm, AE equivalent to the TKR6210, then took out the spacer under the Spindle Arm. Still Rubs. Had to go back to stock. Anyone get these to work?
Also weight. I'm running a skinny battery and pucks. I'm still about 150g over min weight. Anyone know what actually reduces the weight. Real data. I know titanium upper screws would lower the weight. But I better that is something silly like 5g for $100 of screws. Plastic gears in the 3 diffs are good for 9g per diff. But last time I ran those, did not get 1 month before it would eat them. I run indoor clay. I bet the carpet guys would not make it 1 race with 13.5.
#279
Hobbywing Xerun XR10 Pro G2 160A Sensored Brushless ESC (can survive being plugged in backwards, and works well)
Only servo for me is a ProTek. I run the smaller one, forget the model. (High quality and the smaller one works like the bigger ones I run in truggy and 4x4 sct).
Anyone actually weight the shock tower difference with carbon fiber? Hard to believe it is anything significant.
#280
I think protek makes a really good shorty servo. I did mess up the plastic gears in the center diff, but the front an ld rears diff were very reliable for me. Sorry they didn't work out for you. And that HW esc is a good choice. I had mine at 1665 with a full size esc, but I had all CF and titanium
#281
To reduce weight - lightweight body and wing for sure, various aluminum/titanium screws and aluminum nuts are easy items. Picking the lightest motor, esc, rx, and a light LP servo can help a lot. Running short wires, some guys go to 14 gauge wires as well. There are titanium upper shock mounts and titanium lower shock screws. Titanium turnbuckles (slightly shorter than kit length), titanium hingepins, titanium ballstuds. All the carbon parts, specifically the rear tower with built in camber links. Aluminum axles, MIP center driveline, aluminum screws holding the ring gear to the diff case, and plastic internal diff gears are great ways to reduce rotating mass (like you said though, you lose durability with the plastic gear, but if you get the car light enough then it will be easier on the gears). There are also some plastic parts that aren't needed to run the car (rear braces for example) and others that can be shaved down.
It's really not that hard to get the car under 1613, especially if you use a lightweight battery, it's just not that cheap. I got mine well under 1613 without using a lightweight pack (or the lightweight body IIRC), and I'm pretty sure I could probably get it to 2wd minimum weight if I really wanted to, but there's not much of a reason to. The car seams to handle best at somewhere around 1620-1650 for 13.5 and most of our drivers that run mod prefer to be around or above 1700.
#283
hey all. So its about time to rebuild the diffs on my eb. I used the kit diff oils which are 15 30 10.. My boy races, Im just the mechanic now..lol. These weights didn't seem that bad at all, but I dont have any other diff setups to refer from. I did have the 1st gen eb but I don't remember my diff numbers. I did have 2 or 3 different setups but I sold it and I cant find my setup notes anywhere...
Going over some setups online,, it seems like guys are going for the most part,, a bit lighter..
We run 13.5 on med high bite ( but not too often high) clay track thats about 15 second laps. Seems like I'm getting about 50% more wear up front. Which I know is somewhat common for wheeler. Im thinking Im a bit too high up front.
Maybe 10 30 7? Any suggestions??
#284
#285
So I have a comfortable suspension package. Its pretty much where he likes it between the 2 tracks we race. Its the same setup with maybe a mm or 2 ride height adjustments and a couple other things. I have just enough steering with it, although it does push maybe a tinge more than I would like. Ive had 4wd buggies that were better out of corners. But overall, Im a Tekno guy. Just our preference. Maybe do your suggestion but a softer front spring. I could go for that. Were not struggling to ear any jumps between the 2 tracks right now. So less lift wouldn't be a bad thing.
215Likes
