Tekno EB410.2 Thread
#152
#155
One thing to keep in mind about velcro vs clips is the chassis flex. Velcro will affect the chassis flex (typically will stiffen the chassis a touch), this could be good, bad or indifferent depending on your driving style, setup and track conditions.
I run velcro only on the sides. I cut the nubs for the clips off and put the fuzzy velcro there just to keep the body from getting too scratched up on the inside.
#157
If you were to use the body clips, you are suppose to cut the back hole more like a rounded slot rather than a circle shaped hole. The elongated hole allows the chassis to flex and the body clip to move without destroying the body.
#158
#160
Here is a copy of the setup that I am currently using. Buggy is very easy to drive on turf and neutral in the corners. I did try 60K fluid in the center diff but I felt like it reduced my overall available steering and I was a little slower around the track with the change. I think that 35K or 40K might be the absolute max I would be willing to run but more experimentation is needed.
#161
#162
Ok. I’m used to seeing setup sheets for other manufacturers in mm and even a previous sheet in this thread in mm. If the previous sheet in this thread is in fact in mm (as listed on the sheet), it’s quite a ways off from the factory setting.
#163
You need to look at the notes of the set up sheets. I have seen some setups use mm for the washer height.
215Likes
