GS STORM CL-1 THREAD >
Old 04-04-2006, 02:40 PM
  #16
better,
Ive never had any problem with the fuel tank. It fits perfect.
kyracer is offline
Old 04-20-2006, 07:28 PM
  #17
Trader Rating: 32 (100%+)
Guys,
Something I have been doing on bumpy tracks is using the Fioroni rear chassis brace for the Storm CL-1. It mounts up with 2 holes instead of 3 on the rear allowing a little more forgiveness.
Brandon
Brandon Powell is offline
Old 04-27-2006, 07:37 PM
  #18
Hey brandon do you have the most updated setup of Marty's? Ive been looking and cant find it. The one on the GS site is older I think?
runnin rc10 is offline
Old 04-28-2006, 06:27 PM
  #19
runnin , sent you an email .
Old 04-29-2006, 12:34 AM
  #20
GS just published some nice new parts for the GS Storm CL-1:
http://www.buggy-sport.info/include....contentid=3658
vgerdes is offline
Old 04-29-2006, 11:03 AM
  #21
Default KORN'S SUT Truck Set Up
This is Marty's latest SUT Set Up I could find .
SET UP FOR NATIVE Racing/ GS Racing SUT
70 OIL IN FRONT 1.4MM PISTONS
60 OIL IN REAR 1.4MM PISTONS
STIFF FIORONI SPRINGS
2 DEG ANTI SQUAT
3 DEG TOE IN REAR
2 DEG TOE OUT IN FRONT
.5 DEG TOE ON REAR HUB
FORWARD HOLE IN ACKERMAN PLATE
ARMS LEVEL
STOCK SWAYBARS F/R
70% REAR BRAKE/30% FRONT BRAKE
5K FRONT DIFF
50K CENTER DIFF
1K REAR DIFF
UPPER HOLE ON UPPER ARM
SHORTEST REAR CAMBER LINK
THIS IS WHAT I RAN AT THE NITRO CHALLENGE. I WILL LET YOU KNOW WHEN I GET TO TRY MY NEW TRUCK SET UP! I THINK IT WILL BE AWESOME.
Hope this help's .
Old 04-29-2006, 08:00 PM
  #22
jfc_tech's Avatar
2 DEG ANTI SQUAT
3 DEG TOE IN REAR
ARMS LEVEL
STOCK SWAYBARS F/R
5K FRONT DIFF
50K CENTER DIFF
1K REAR DIFF
Hope this help's .
brandon thanks for the info.
jfc_tech is offline
Old 04-29-2006, 08:06 PM
  #23
No problem.
Old 05-15-2006, 06:53 PM
  #24
New parts from GS Racing
http://www.gsracing.com.tw/informati...led.php?id=126
Old 05-17-2006, 04:34 PM
  #25
How interchangable are CL-1 parts with the Storm pro buggy?
TIA
Rod
gatermaxx is offline
Old 06-06-2006, 11:56 PM
  #26
Cl - 1 Brodie's Avatar
i don't think the cl-1 parts are compatable with storm pro parts.
Hey does anyone know where i can get good parts support for the cl-1 in Phoenix Az. ( u know, say parts already on the shelf etc...)
Cl - 1 Brodie is offline
Old 06-07-2006, 12:02 AM
  #27
oh & what outdrives (apart from gs, that fit perfectly) does anyone use for longer wear & tear.
Part from these tiny issues this is theee best buggy i've driven so far.
Old 06-07-2006, 02:06 PM
  #28
Brodie, Amainhobbies.com is good to deal with on replacement parts.
Old 06-07-2006, 02:23 PM
  #29
i already order from them, i mean say you walk into a shop thats within 10 to 30 mins & then there's the parts on the shelf, bit like going to wallmart & getting a tv. but amain is a good source otherwise.
Old 08-18-2006, 07:50 AM
  #30
TripleX-JT's Avatar
What engine is on the CL1 RTR? I see it on all the websites but I cant find any info on it. I am looking at picking one of these bad boys up when they become available in mid Sept.
TripleX-JT is offline
