Hb Racing E819 Ebuggy
#91
I can’t help adding bling to my build. Today I’m going to install my speed control..
#92
Hi, I don't think it's possible, there's not enough space for the receiver box. Ronnefalk placed the receiver without the case next to the Esc... I think I will do the same... ( I cannot insert the link, you can find it on circusrc.com if you search for 2020 The Dirt Nitro Challenge and David Ronnefalk).
I ended up reaming a hole in the receiver box so that the post of the motor had room.
#93
What is the fix for the inserts on the rear arms? The screws keep pulling thru the insert??
#94
#95
Both my cars, after every run inside corners screws pulled thru
#97
#99
Sofa king thank you ill give that a try. I know the screws are not over tightened.
#102
#104
Can I get some info on it
How much does it cost how fast does it go (stock) I can upgrade later. How available are parts does it break often.
