Team Associated B74 4wd buggy
#886
Jconcepts also has new rear alu hubs for B74
https://www.jconcepts.net/shop/b74-a...r-hub-carriers
#887
I just bought a set of the DCV axles from AMain and they're much shorter than the stock axles. I thought they were sending out the full length ones? Anyway, do I see if longer axles are available or just find some low profile wheel nuts? I'm aware there was a dimension issue with the stock axles not passing tech.
*edit* I just ordered some low profile nuts from rcspeedsecrets.com so I'm good.
#888
Mainly bought them for the stiffness of aluminium over the flimsier plastic hubs. I haven't had an issue with breaking the stock plastic hubs but I almost always prefer the way the aluminium rear hubs feel on my 4wds.
#889
So when does the version of the b74 come out without the adjustable diffs to match the 22s weight?
#892
The screws are a nice feature but found out it is way too easy to pinch the hingepin in the hub height insert and reduce the hubs free rotation. Maybe this isn't as much of an issue at +2/3 but using +1 it was annoying so I didn't worry about locking down the insert and removed the grub screws.
#893
Hey fellas - new here. Just picked up a B74 and am having an issue with the bottom of the spur gear lightly rubbing against the chassis. Shredded a couple spurs and even a pinion before I found that was the issue. Anyone else with this issue and have suggestions to diagnose and fix it? I’ve taken apart the slipper and reassembled multiple times to no avail. Running a 78T. Cheers
#894
And there is always the 75 tooth spur gear for more options.
I just added a gear chart to the wiki; minimum and maximum pinions were measured for 72 and 78 spur gears, 69 and 75 teeth values were calculated from the minimum and maximum sums of teeth. Mimimum and maximum pinions may vary between manufacturers, though.
#895
#896
#897
#898
That gearing chart needs to list that only 72/78 fit the gear diff and the other ones are for the slipper only.
