Kyosho Ultima RB7 Thread
#511
Hi guys, new owner of an RB7 here... I'm wondering what the typical basic ride height ought to be out of the box? I'm nearing the end of my build and my ride height front to rear seems waaaay out of whack... like the rear is sitting significantly higher than the front, and from what I can tell I've set everything up exactly as listed in the manual. Should the front/rear by same height by default? (I tried posting a pic but the forum won't let me)... any suggestions would be much appreciated, as I fear I may have installed something wrong but have been racking my brain trying to figure out what.
#513
But ride height even or the rear slightly higher is what you're aiming for. And as mentioned, 22-24 is a good clay starting point. Check out petitrc for some setup sheets.
#514
Thanks guys for the tips... will take a look!
#516
#520
Super Moderator
They are very similar and I say that because a lot of the aftermarket companies say wheels that fit the RB7 also fit the Associated vehicles. I tried to use JConcepts wheels but they rubbed on the steering knuckle so I spaced them out .5mm and that seemed to resolve the problem.
#522
What is everyone doing for gear diffs? Can't seem to find the kyosho one in stock anywhere.
#523
I seen those. I was just seeing if they're was other options before I went that route and have to wait a month to get it.
#525
I also noticed that the RB7 and RB7ss look to be sold out at the major online retailers and some are even using the word discontinued. Those who still show them are mostly asking full price or above. Has anyone heard if a replacement is imminent? I hope a replacement is coming especially if the parts can retrofit the existing cars
