Like Tree116Likes
Mugen MBX8 Eco
Old 09-26-2018, 11:20 AM
  #76
Theetonster's Avatar
Originally Posted by rcgod
5/32” chain saw file is cheap and available at most hardware stores. Works better than any other reamer or drill bit I’ve tried. FYI.
Thanks for the tip! Just picked up a couple of files for 7 bucks at lowes like you said. I should get my mbx8 tomorrow. Now I am prepared !
Theetonster is offline
Old 10-02-2018, 01:18 PM
  #77
I saw that the new car has the steering posts keyed into the chassis now. Is this true? The questions however, has this fixed the problem of the chassis screw working out over time? How is the maintenance compared to the old car in this regard? Is it easier to remove the posts?
mdavis1432 is offline
Old 10-02-2018, 01:31 PM
  #78
slackinoff's Avatar
I did not own the 7, but I have had zero problems with the chassis screw working out on my 8. I have always used a little dab of blue locktight on the posts. The posts are easy to remove, just need to pull off the top steering plate. The HTD diffs can be pulled out super fast. I love working on my MBX8 Eco.
slackinoff is offline
Old 10-02-2018, 01:43 PM
  #79
Thanks Slackin.
Ive raced their buggies since the MBX5 and its always been the same problem. You can use all the loctite in the world, and they are still going to work loose. Its been a problem on all my cars, but was happy to see they adjusted it for the new car. Thanks for the help!
slackinoff likes this.
Old 10-02-2018, 01:44 PM
  #80
Old 10-07-2018, 09:40 AM
  #81
Default Shocks
I just drove my mbx8 for the first time. I noticed the rear is loose. I ordered some softer springs and brass pistons for it. Just wondering what anyone else has done about this.
Old 10-07-2018, 05:26 PM
  #82
Trader Rating: 16 (100%+)
I just got on here to ask the exact same question! First time running mine was today also. I'm thinkin of trying 5/4/1, I have 5/5/2 in it. Or changing to regular diffs (not HTD's). Or underdrive in the rear. My MBX7 drives way easier (and faster) with regular diffs and underdrive. I had a AE buggy that was similar in feel to this 8eco, like a 2wd feel. Not liking these HTD diffs!
Tommygun1 is offline
Old 10-07-2018, 06:51 PM
  #83
I'm building my first MBX8 and I have a question. What does the small set screw that screws into the rear wheel hubs do? What exactly is it securing? I screwed it in. I just want to make sure it's in correctly. Thanks.
DapperDan is offline
Old 10-08-2018, 03:26 AM
  #84
werner sline's Avatar
those little screws are not securing ; they are suposed to be an access to oil the ball bearings
werner sline is offline
Old 10-08-2018, 09:51 AM
  #85
I put the underdrive diff in the rear (42/12) and it was still loose on power and off power.
Old 10-09-2018, 02:18 AM
  #86
Are you using the standard setup mate?
pit biatch is offline
Old 10-09-2018, 03:51 AM
  #87
HyperMBX7R's Avatar
All mugen cars need some time (~1 gallon or 15 runs (Eco)) to get a free drivetrain without a loose rear.
Theetonster and slackinoff like this.
HyperMBX7R is offline
Old 10-09-2018, 06:33 AM
  #88
I did come across something Adam Drake said that was similar to what you're saying. I didn't realize that you needed to break in new buggys. I am new to offroad and that's why I am in here asking questions. Thanks
Old 10-12-2018, 12:16 PM
  #89
rcgod's Avatar
Trader Rating: 33 (100%+)
So what's the deal with all of the slop in the diff cases? In the process of building mine and there is a lot of slop between the diff bearings and the diff cases. Like 1mm front and back. Seems like the bearing od is too small.
rcgod is offline
Old 10-12-2018, 12:31 PM
  #90
KINGZJ's Avatar
Once you tighten everything up when its all bolted down to the chassis the slop mostly goes away at least mine did.
KINGZJ is offline
