Rock Crawlers Only
#692
I'm only geared 16/56 (from memory) and have set the throttle curves so that the majority of the power doesnt come on till right at the end. Gives the best of both worlds, silky smooth down low with loads of top end. Not to mention awesome efficiency, essentially zero maintenance and very low temperatures.
#694
I've got one of those exact motors in my 4wd SC, and it would be far too long.
Remember, those hobbywing motors are 4 pole, so produce excellent torque compared to a 2 pole like the others listed.
I used to run a 10.5t on 3s in my wraith, it was OK, but nothing mind blowing.
#696
Have not had much wrench time but i finally got the motor I think will be the ticket for me installed. Hobbywing 3656sd 3400kv so I'll be able to run 3s. Now back to mmp, skyrc toro 120a or brushless hobbies lt4 120a. I'm running a bec so none of the specs there matter. All three have good points like carry the program card to adjust in the field but the toro wifi has more adjustibility on the go.
#697
Haven't done a huge amount to mine lately, scx10 got some new rcbros zero Ackerman arms, locked up rc spool for the front and finally have the shocks just about where I want them, a little more testing is still needed.
#700
#701
It's the motor/esc combo that's built into the motor and only good for 4.8-8.4 volts it says. But it looks very clean setup. Its the ddrive setup. Looks like I'll find out in a week or so how it works. I really like how clean they look. Also takes the choice out of what esc I'll run for now. If its not enough itll go in one of the kids crawlers or my next build.
#702
#705
Mmp/hobbywing 3656sd 2s smooth. Need to gear down and go 3s I think. Running 20/87 slowest I can move is too fast but not enough top speed. going to try 16/87 i think. Really like my mmp but they always seem to have a higher start up speed. Really want to try a tekin with this. I have a brushless hobbies lt4 and a toro ts120 but just don't know that I trust either one for this.
