Donathen RC Custom Made Products: Charge leads, power supply cables, and more!
#76
![Default](https://www.rctech.net/forum/images/icons/icon1.gif)
Received my leads the other day, awesome quality! Super pumped about it! Can’t post a picture yet but they are awesome! Haha
#77
We have reached our 4500 page like benchmark! Which means we will be giving away a custom DRC product, shipped anywhere in the world for FREE!
Comment on our live video before it ends at 9:30 EST on our Facebook page, to enter to win. https://www.facebook.com/Donathenrcracingproducts
![](https://cimg3.ibsrv.net/gimg/www.rctech.net-vbulletin/1200x900/4500_page_like_giveaway_max_quality_e93613583e390f7d192698c428b43e75b72b0993.jpg)
#78
We recently launched our 2s-6s balance charge leads, in replacement of our: 3s,6s, and multi-cell balance charge leads. They have all of the customized and durability features you come to expect from DRC.
Choice of:
20+ sheathing colors
9 heat shrink colors
custom heat shrink
battery connector
charger connector
length
wire awg
and more options!!! Check them out at =AT2lB4aaA-8J2yUgDmoKaqAFpvSyk8XAAv5vAkKIrzVftDwNA22Bqj_yh8r5 XVUq6_b9DxbYGP_txEeJFJNkYCY6AvTgbctNtQSvwsUQh5PTpP 9ZcVL7Kl4cA6OAXYOcnYFMQT2AZl0MYVJ8GBEjP7yVLPp_N5ue 1ZxotH-ftG1HDlhDG2te0JTCn54YDdQ]donathenrc.com or message us!
![](https://cimg3.ibsrv.net/gimg/www.rctech.net-vbulletin/1640x2000/20200902_112810_1__37ba4298f12bfca54946e45339df4d5abdb3e43e.jpg)
![](https://cimg5.ibsrv.net/gimg/www.rctech.net-vbulletin/1440x2000/20200908_083937_4851f3613f75add54b84041156faec6d12e0d080.jpg)
![](https://cimg4.ibsrv.net/gimg/www.rctech.net-vbulletin/1420x2000/20200908_083858_f8d8ba18def09bd46dee7864320da304e36e1e0d.jpg)
![](https://cimg7.ibsrv.net/gimg/www.rctech.net-vbulletin/1500x2000/20200908_084010_f4abb3ac268fe1a02300fc293e09d576dd445632.jpg)
Choice of:
custom heat shrink
battery connector
charger connector
length
wire awg
#79
Improving our killer line up of leveled up fast charging/data capable phone charge leads is our MAGNETIC phone charge lead!
This lead features, the same amazing performance of our standard phone charge leads: 3 amp super faster charging, data capable, 12 month warranty, AND choice of colors just for you!!!
We have these in all 3 phone styles, in 3 and 6ft lengths to start with. As always these leads are handcrafted to order right here in the USA!
We also have additional ends that can be purchased, to leave in your other devices. Please find the videos in the link for how amazing these cables work! https://www.dropbox.com/.../AADUTfi0QBgglH-igcKy63Zda...
Check out a couple of short videos proving how amazing these magnetic leads are! They are available at donathenrc.com or message us!
![](https://cimg0.ibsrv.net/gimg/www.rctech.net-vbulletin/2000x1504/20201008_093840_b59e6b82457009a8889f9557a4651a9abf19601c.jpg)
![](https://cimg7.ibsrv.net/gimg/www.rctech.net-vbulletin/1740x2000/20201008_094001_908c786ce3e103eb162971d7313a688e7d241dc7.jpg)
![](https://cimg8.ibsrv.net/gimg/www.rctech.net-vbulletin/2000x1325/20201008_093628_1fba0b1b434755c1b87909da78466e74cb737071.jpg)
![](https://cimg2.ibsrv.net/gimg/www.rctech.net-vbulletin/1826x1919/20201008_093908_2c10c1fac52bc1f72389ef56476e70eeab59fe0a.jpg)
![](https://cimg4.ibsrv.net/gimg/www.rctech.net-vbulletin/1723x1723/20201008_093925_282448f9b4eebc21578005c0e2bfde21d6c61c06.jpg)
![](https://cimg5.ibsrv.net/gimg/www.rctech.net-vbulletin/1575x1907/20201008_093936_3cab104e51ed2a9f938309392aa062aa97f12092.jpg)
![](https://cimg8.ibsrv.net/gimg/www.rctech.net-vbulletin/2000x1504/20201008_100805_393adef9260505dc075f03a529cf883703a17506.jpg)
#80
Inertia Tungsten alloy is 225% heavier than steel, 200% heavier than brass, and 150% heavier than lead.
· Inertia’s Proprietary Tungsten Alloy screws weigh in at an impressive 4.3 grams per 5x - 6mm screws vs 1.8 grams for standard steel screws.
· Yield's a 2.5 gram net gain per 5x screws used - at the lowest place in the car.
Yield can be even greater if you use 8mm in place of 6mm screws where possible.
· Frees up valuable space on top of the chassis.
· Gives greater ability to place electronics and weight exactly where you want them.
· Can also be useful to tune the vehicle, with weight bias. This is done by easily by isolating the Inertia Tungsten Screws to one area of the car.
There are a select few ways to increase corner speed; one of which is to lower the Center of Gravity in your car - or simply placing weight as low as you can. Inertia Tungsten screws put the most weight at, the lowest possible point, the bottom of the chassis.
"Simply switching a car over to Tungsten screws allows for more corner speed, and faster laps."
Lastly, our Tungsten Screws have been tested against several brands of steel screws. The team have found that they've outlasted steel screws (head deformation) and did not deform like some steel screws can over time. This is due to Inertia's proprietary Tungsten Alloy formula.
These v2 tungsten screws have an even heavier and more durable formula, than our first batch. Most importantly they have a true 2mm hex, with the same amazing specifications as our other Inertia screws!
· Available in M3 and 4-40 sizes.
Available at: donathenrc.com
![](https://cimg4.ibsrv.net/gimg/www.rctech.net-vbulletin/861x755/tungsten_screw_countersunk_650cd13c50f14c9fe5934b85cdae6d1534c54355.jpg)
![](https://cimg5.ibsrv.net/gimg/www.rctech.net-vbulletin/634x797/steel_screws_weight_ecf476cbde3aade6d6c7b2befe10daa226b3487f.png)
![](https://cimg6.ibsrv.net/gimg/www.rctech.net-vbulletin/697x840/tungsten_screw_weight_1_231cda0a82586fd2a7b5cfcefc43ec677368f25b.png)
#81
DRC is excited to announce the v2 of our heated lipo products: Heated Lipo Sleeve!!!
These are available in 2 variants, a standard non customized and a customized version.
What makes these different from a heated lipo safe?
Temperature control: 3 settings, low medium and high.
Expendable: Fits up to 3 1 cell, 2 2 cell, or 1 4 cell batteries.
Power: Powered off of ANY usb port.
Heating: 4 heating elements to provide equal and controlled heating to every part of the battery.
These are meant to be used inside of a lipo safe/sack.
They are available for pre-order now, we expect to have them by December 1st! Check them out at donathenrc.com or message us!
![](https://cimg1.ibsrv.net/gimg/www.rctech.net-vbulletin/1836x1836/20200813_091529_96dd931857b6f7375b525195e44316f6b7b1acf1.jpg)
![](https://cimg2.ibsrv.net/gimg/www.rctech.net-vbulletin/1836x1836/20200813_091616_e80af835e08483f092f4026843ee29b289a74d53.jpg)
![](https://cimg3.ibsrv.net/gimg/www.rctech.net-vbulletin/1836x1836/20200813_091845_8f1a64286e75f6f376054e3fe25e34f2ce66c32d.jpg)
![](https://cimg4.ibsrv.net/gimg/www.rctech.net-vbulletin/1733x1499/20201006_092221_b82692ef7a2bb5398b807befa27724d314120588.jpg)
#82
Last year we had announced our first year of "Black weekend" sales. This year will be no different!
We will be offering sales on items for 24 hours only, each day will have a different sale. The details will be announced the day of the sale, these will posted on our website as well as our social media pages.
If you do place orders on multiple days, we will combine these orders and refund any excessive payment for shipping, once the order has shipped.![](https://cimg6.ibsrv.net/gimg/www.rctech.net-vbulletin/1080x1080/black_friday_max_quality_34e9474c693fe701aa8e147fe41576d8fe363af2.jpg)
#83
Today is our spectacular Sunday sale! We are offering all of our sensor wires (the regular, extremely durable, and fully sheathed and extremely durable) at 50% off!
Your choice of length from 50-275mm in flat or tube style! You can also choose your choice of colors with either of the extremely durable sensor wires.
Part 2!!! 50% off of our bullet connectors, thats our 4mm, 5mm, 4-5mm stepped, and our 4/5 double sided connectors!
Get yours at donathenrc.com No need for coupon codes, the price is automatically changed on the site!
This sale will only last 24 hours! Saturday,Sunday and Monday are new sales that will be announced day of sale. If you place multiples orders we will combine shipments and refund any excessive shipping, once the order ships.![](https://cimg1.ibsrv.net/gimg/www.rctech.net-vbulletin/900x900/img_20201129_081241_638_9153b3bfd097b990898062a69b6fc0e4ac6b956b.jpg)
#84
Do your phone chargers fit into an otter box case?
#85
#86
![](https://cimg0.ibsrv.net/gimg/www.rctech.net-vbulletin/1080x1080/untitled_design_max_quality_02749f5480ddddbda080e26f52ec1935c9448acc.jpg)
Comment on the live DRC Facebook video before it ends at 9:30 EST for your chance to win a FREE custom DRC Product shipped anywhere in the world!
#87
Pm sent
#88
We have reached out latest milestone of 4700 page like's on our DRC Facebook Page. Comment a friends name, and share FACEBOOK or INSTAGRAM post to enter to win a Custom DRC product shipped FREE anywhere in the world!!! https://www.facebook.com/Donathenrcracingproducts
Entry will end February 2nd at 5pm EST, and the giveaway will occur February 2nd at 9pm EST, live on our DRC Facebook Page.
![](https://cimg4.ibsrv.net/gimg/www.rctech.net-vbulletin/1200x1200/untitled_design_max_quality_1__e04ce1c8e66ed76bdcb0ed3505b30e258a0dc773.jpg)
#89
If you're going to be in Virginia or near it during the 10th-14th of March come on out and say to us at Coastal RC in Norfolk VA.
We will have our ordering stuff with us, as well some products in the hobbyshop.
![](https://cimg5.ibsrv.net/gimg/www.rctech.net-vbulletin/653x960/154334610_10226350938868328_4924495454172818666_n_b40d44af16f7daaf97d6f52e130e9d0ade0926ea.jpg)
#90
Tomorrow at 9pm EST, Live on our DRC Facebook page!
https://www.facebook.com/Donathenrcracingproducts![](https://cimg6.ibsrv.net/gimg/www.rctech.net-vbulletin/1080x1080/4800_page_like_giveaway_max_quality_1d5405a35202ee986cdc33077fcbb9c5585adc5b.jpg)
