Go Back  R/C Tech Forums > International Forums > Australian Racing
Adelaide Radio Controlled Raceway Inc. >
Like Tree116Likes
Old 08-28-2016, 09:32 PM
  #8251
Coopz's Avatar
Trader Rating: 22 (100%+)
That looks excellent, nice work
Coopz is offline
Old 08-28-2016, 10:37 PM
  #8252
Hotwire's Avatar
Selling my AE SCT package if anyone is interested - haven't made a single meet due to family so time to move it on.
http://www.rctech.net/forum/australia-sale-trade/959399-sa-associated-sct.html
Hotwire is offline
Old 08-28-2016, 11:34 PM
  #8253
ARCR Inc's Avatar
IT’S BACK
Our annual two day trophy meet OFFROADERFEST will be here in October.
And entries are open.
For more details Below checkout the flyer on the link below.
So get your entries in early for our biggest event this year.
ARCR.org.au
*Note : There is only Junior Stock this time, no Novice.
ARCR Inc is offline
Old 08-29-2016, 12:53 AM
  #8254
chillibutts's Avatar
Originally Posted by Reflexia
Anyone got a left handed drill bit set I can borrow (or similar screw removal device)? I've got a 3mm countersunk stripped screw on a chassis
Ah ... I've got one of those in my gear diff housing
I used a dremel to get a slot across the screw and unscrewed with a slotted screw driver. Still using that screw too, and I didn't have an equivalent. Its been in and out a few times.
What to borrow the dremel?
chillibutts is offline
Old 08-29-2016, 01:08 AM
  #8255
ARCR Inc's Avatar
ARCR Inc is offline
Old 08-29-2016, 01:09 AM
  #8256
Reflexia's Avatar
haha, to add it to my other three Dremels ?
I don't want to hurt the Carbon its attached to
I think I'll have to hammer in a small flat head screw driver again Might pop by a few serious hardware stores and see what's available. Bunnings was no help but not really their thing. Walked away with some other tools though hehe
Reflexia is offline
Old 08-29-2016, 03:59 AM
  #8257
LOL. No sign of carbon on my truck!
FYI diff housing did get an unintended mod at the same time! Oops
Old 08-29-2016, 04:06 AM
  #8258
I'll have a look at work tomorrow to see how small the easy outs I have are.
Tyrone
tyzer is offline
Old 08-29-2016, 04:21 AM
  #8259
sdrob's Avatar
hey mate last time i just drilled mine out until the head snapped off then removed the part completely from the chassis.. then using a vise or pliers on the remaining 2-3mm of screw i twisted it out..
3mm scres are too small for extractors from my experience..
sdrob is offline
Old 08-29-2016, 04:53 AM
  #8260
What he said.
Can you drill a small hole onto the head then hit a alen key into the hole you have drilled? Has worked on a door lock for me before but it is made out of softer steel
Enjoy Gully
Gully85 is offline
Old 08-29-2016, 06:58 AM
  #8261
Reflexia's Avatar
Originally Posted by Gully85
What he said.
Can you drill a small hole onto the head then hit an alen key into the hole you have drilled? Has worked on a door lock for me before but it is made out of softer steel
Enjoy Gully
Yeah, that's something I was considering. It's a hex screw to begin with, so would have to force a slightly large one in, or attempt a corner to corner with the flat heat. It also has red loctite, which will make it even more annoying ( probably the cause of the original rounding.
Easy Out, that's the thing, if they go that small, thanks Tyrone.
Last time I drilled a countersunk one out it didn't go great, had to replace the part the shaft was stuck in ( could probably do that, but its vintage :-) ).
As a man who hordes tools, I thought there must be a tool for this
Thanks for the ideas guys!
Reflexia is offline
Old 08-29-2016, 02:29 PM
  #8262
I have used torx bits in the past just tap one in that's slightly bigger,they seem to bite in well.
mythical is offline
Old 08-29-2016, 02:54 PM
  #8263
Benzaah's Avatar
Trader Rating: 24 (96%+)
It also has red loctite, which will make it even more annoying ( probably the cause of the original rounding)
Red thread lock is the enemy of RC. Purple ftw. And you can heat up the screw with your soldering iron and the thread lock will weaken.
Benzaah is offline
Old 08-29-2016, 04:09 PM
  #8264
My old man showed me a trick years ago. Think he glued the hex bit to the screw, using loc tight or something similar, then like magic it came undone. Heating the screw is a good idea too. That will weaken the red stuff.
My favourite gear is the blue stuff, tastes horrible though (don't ask that shit gets everywhere if your not carefull)
Gully85 is offline
Old 08-29-2016, 05:21 PM
  #8265
Reflexia's Avatar
What is this purple you speak of? I only have Red or Blue!
Reflexia is offline
