Go Back  R/C Tech Forums > International Forums > Australian Racing
digital steering servo problem >
Old 07-15-2010 | 08:40 PM
alexisonfire's Avatar
Default digital steering servo problem
just noticed a fault with my thunder tiger digital servo, at times it wont drive in one direction from neutral, if i go full left and right it never misses a beat.
i can hear the high frequency signal from transmitter movement trying to drive the servo but it just freezes now and again, then comes to life
any thoughts? i know its not the best brand but hasnt let me down so far, its the one with the silver heatsink case.
alexisonfire is offline
Old 07-15-2010 | 10:24 PM
Adro's Avatar
sounds like a stripped gear, pull the top of it and you will probably find the small plastic gear is missing some teeth.
Adro is offline
Old 07-15-2010 | 10:47 PM
but sometimes it drives sometimes it doesnt, sounds more like the digital circuit/motor has issues to me.
Old 07-15-2010 | 10:53 PM
cannon's Avatar
Open it up and have a look. Then it eliminates that option
cannon is offline
Old 07-16-2010 | 02:49 AM
Thumbs up
just looked there is no problem with the gears! go broncos!!!
Old 07-16-2010 | 02:57 AM
ozipanda's Avatar
Does it only happen with that servo? If so check soldering of servo leads to circuit board.
If not, it may be a transmitter problem, potentiometer.
ozipanda is offline
