WHICH SERVO?
WHICH OF THESE WOULD BE BEST FOR 1/10TH BUGGY
I need one that the deadband can be adjusted as there seems to be some wandering of the signal from the reciever
Futaba S9551
hitec hs-7775MG
KO propo PDS-2511
Ko-propo PDS-2413
cost IS a factor
But I like the small size of the TRUE "low profile"
Futaba S9551
hitec hs-7775MG
KO propo PDS-2511
Ko-propo PDS-2413
cost IS a factor
Steve, i know a few guys are now using the Blue Bird servos from Hobby King, great on the budget and good quality, Metal Gear, High Speed, more than enough torque and CHEAP!
http://www.hobbycity.com/hobbycity/s....10sec_/_46.5g
don't mind spending $70+ for a good one
DYS Metal Geared fast need to check speed again 13kg yes its annalog but brutally good.. 45 bucks - nuff said
BUT you can never pass up the KO,s if you have one..
along with the lipos oh and the wheels/tyres, sorry Nick I forgot they were yours
Dunno I didnt have any there... what are you after is it imperative to be digital there are quite a few on the market.. Also look at the Savoxes..
Looked at the savoxs
situation is that my buggy does not center accuratly 100% of the time
Tried 2 servos, no difference
tried 3 recievers, no difference
checked V output of transmitter pot, within 1 mV
VARIATION OF DEFLECTION IS PROPORTIONATE TO EXPONENTIAL OF STEERING, therefore rulling out binding steerring
thought is to increase neutral band so the deflection is not relevent
even looking at a $500+ Futaba 3vcs setup
but if I do, I'll be looking at the divorce courts
May try swapping throttle and steering pots on the transmitter next
really starting to bug me
ive got 4 of those ko low profile servos, obviously for 1/10th steering use. awesome servos. no dramas.
won't touch any more ko's for 1/8 offroad use ever again. killed my 4th and final one at the recent state titles
..was using full size ones rated between 12kg and 15kg.
