Mod motors
Old 03-24-2010 | 10:49 PM
  #16
H I's Avatar
H I
I'm getting 5.5 and 4.0 as every thing else is out of stock.
I drove Keefys SP5.5 and power is perfect for SMA... well for me anyway.
Ant, I'm going to SA title later this year. What motor do you use on 12th scale over there? Track looks very nice but hard to tell size from pics.
H I is offline
Old 03-24-2010 | 10:52 PM
  #17
Yokomo_Ant3's Avatar
I dont know, havent run 1/12th since nats I would say 4.0. Thats whats in it now Track isnt quite as big as Whalan, but bigger than SMA. Its very technical. 23 sec lap times i reckon in 1/12th
Antoni
Yokomo_Ant3 is offline
Old 03-24-2010 | 11:15 PM
  #18
Hugh Jazz's Avatar
Thats Good to hear. I will be there as well for 1/12th.
Hugh Jazz is offline
Old 03-25-2010 | 12:06 AM
  #19
Ok as brad said there is little reason to buy big power motors as you will find very little use for full throttle. Last years nats was WON with a 4.5 at Whalan. This is with an exp driver who still though there was plenty of power.
Now for some quick facts... YES you can go faster in a straight line with more motor... BUT.. How much time do you spend in the turns? Even tracks like Whalan you still spend 80% of the lap turning the steering wheel. Because of this throttle control directly effects your lap speed.
The Moral is if you want consistent lap speed GET a motor you can handle. For most ppl on current technology that is around 5.5t even on big tracks.
Also stay away from LRP. They are easily the hardest motors to drive fast with too much bottom end. If you have to run one run VERY LONG wires to your motor to help prevent the motor from transferring too much heat to your ESC.
Dragonfire is offline
Old 03-25-2010 | 12:31 AM
  #20
cannon's Avatar
Hiroshi,
I will give you a new free original SP style 4.5 motor to play with
It is just a Feigao 4.5 so you can play around with it to see how you go.
cannon is offline
Old 03-25-2010 | 01:02 AM
  #21
mangoman's Avatar
Whats happening in SA? Are they giving free driving lessons?
Cause i could do with some of that too!
mangoman is offline
Old 03-25-2010 | 01:09 AM
  #22
Hugh Jazz's Avatar
I just want to be slow in as many states as i can. I am slow in the ACT, SA but Hiroshi beat me to that spot in NSW
Old 03-25-2010 | 01:12 AM
  #23
Me_MrTyson's Avatar
HI,
Looked up the RPM between the models FYI
4.0t = 9100 rpm/Volt
4.5t = 8000 rpm/Volt
5.5t = 7000 rpm/Volt
These are all based on SP V3 gearing sheet.
Alex
Me_MrTyson is offline
Old 03-25-2010 | 03:05 AM
  #24
H I's Avatar
H I
Wow, it's pretty big jump from 4.5 to 4.0 than I thought.
H I is offline
Old 03-25-2010 | 03:22 AM
  #25
Me_MrTyson's Avatar
Going to be honest..
I also was thinking it was no more than the 500 rpm/Volt between 4.5 and 4.0
There seems to be another 1000 rpm/Volt increase to 3.5 being 10100 rpm/Volt
But then 2.5 is 2 hp or something like that, funny old world hey
Alex
Old 03-25-2010 | 09:23 AM
  #26
Originally Posted by cannon
Hiroshi,
This would be fine to play with...
Old 03-25-2010 | 07:12 PM
  #27
H I's Avatar
H I
Hiroshi,
I'll take that offer thanks.
Can you give it to Martin tonight?
I'm going to take Troys advice and get my self SP5.5 and Novak6.5
Thanks to all for help.
H I is offline
Old 03-25-2010 | 07:36 PM
  #28
mangoman's Avatar
Hiroshi, thats what my 5.5 is....
One of those, i also have one of those in a 4.5 and 3.5 (but i dont want to see you break your car again!)
mangoman is offline
