Corally Phi Thread
Old 03-04-2008 | 03:10 AM
  #121
mazmo's Avatar
Originally Posted by s.nicholson
MMM i believe you should just maybe put your car back to kit setup and start out with everything kit with about 4 droop front 3 rear
Cool ..... do you measure droop from bottom of the suspension arms, or measure lift in chassis until wheels lift off the floor ....
Everyone seems to do it different
Cheers
mazmo is offline
Old 03-04-2008 | 04:30 AM
  #122
s.nicholson's Avatar
Cheers
Its pretty much personal preference i measure by droop blocks and just under the corner of the arm so those measurements are for blocks, but i know ari measue by chassis lift so pretty much its just what you are comfortable with and used too.
s.nicholson is offline
Old 03-05-2008 | 05:57 PM
  #123
Swamp Rat's Avatar
Guys
What Hard Case Lipo's will fit in the PHI
only 21mm between chassis and top deck.
Shane
Swamp Rat is offline
Old 03-06-2008 | 01:20 AM
  #124
penmark67's Avatar
Default Spring rates
Hi Guys
Does anyone know what Lb the Red and yellow TRF springs are? The Reds have more coils than the yellows and feel slightly softer.
Thanks Mark M
penmark67 is offline
Old 03-06-2008 | 02:27 AM
  #125
Originally Posted by penmark67
Hi Guys
Thanks Mark M
Nah sorry mate i would not be able to tell you, I have never used TRF springs before in my life, Maybe just check out Tamiya website they might have spring listing on there.
Old 03-07-2008 | 09:24 PM
  #126
mazmo's Avatar
Tried the kit set up .... awesome. Should have tried it before, instead of persiting with set up I purchased car with.
Thanks for your help.
Just a couple of questions:
- setting up for high grip tracks ... like Fairy Meadow (Illawarra). What change
would you recommend ? I was thinking shortening the camber links by one hole front & rear ?
- I have TRF shocks .. any special set up changes for those ?
mazmo is offline
Old 03-07-2008 | 11:19 PM
  #127
Illawara you should run around 14 front 12 rear if still a little bit to grippy try standing ya shocks up a hole or two.
Old 03-07-2008 | 11:22 PM
  #128
OLD 69's Avatar
Company Representative
Whenever i go down there i start with shorter links and soft sway bars, always works for me. I still run fairly soft springs too (14poundsF/R)
...Ari
OLD 69 is offline
Old 03-08-2008 | 12:38 AM
  #129
mazmo's Avatar
Thanks Ari
...Ari
mazmo is offline
Old 03-08-2008 | 01:15 PM
  #130
mazmo's Avatar
Thanks Simon, would that be same with and without sway bars ?
mazmo is offline
Old 03-08-2008 | 02:29 PM
  #131
mazmo's Avatar
Mark,
Found this info on RC Tech :
Tamiya
Spring Rating [lb/in]
Purple 22.72
Gray 20.91
White Short 17.24
Blue Short 15.27
White 14.82
Blue 14.08
Yellow 13.33
Red Short 13.24
Yellow Short 12.90
Red 11.86
Cheers Alan
Hi Guys
Thanks Mark M
mazmo is offline
Old 03-09-2008 | 03:00 AM
  #132
mazmo's Avatar
Default Progressive Springs
Though I'd try some Rayspeed springs that I had lying around, as they are progressive. 17lb (like kit PHI)
Result was great ... for me the car seems more settled & consistent. Lots of grip every where.
Cheers
mazmo is offline
Old 03-09-2008 | 05:42 PM
  #133
Um i never really tried the car much without bars but i say it would be pretty close to that still.
Old 03-15-2008 | 07:34 PM
  #134
Had my first race with my wifes corally at the western aus states last weekend and what can i say that are a great car easy to setup and steering couldn't say i had none, so in all the best car i've driven and between you and me she's not getting it back ethier.
twitch_1 is offline
Old 04-05-2008 | 02:12 AM
  #135
mazmo's Avatar
Default Excel Springs
Hi Simon,
In an earlier post you mentioned tha you use excel springs, are they the same length as corally springs ?
mazmo is offline
