Corally Phi Thread
Old 10-04-2008 | 08:22 PM
  #226
revsinc's Avatar
Default 08 Diff
Is the new 08 diff rebuild kit part # 79683 available yet ?
revsinc is offline
Old 10-05-2008 | 10:18 AM
  #227
Got one with my two 08 diffs about a month ago...here in the US from Corally USA.
Still Bill is offline
Old 10-22-2008 | 10:03 PM
  #228
TWISTED
Guest
Posts: n/a
Here you go guys.
Front
Front Tires: Jaco Purple. Will have to put a PHI arm shim on the inside of wheel.
Tire additive: 1/4 front tire ( TQ Modified) I have also tried Paragon and it`s pretty good aswell
Ride height: 4mm
Kingpin Lube: Light
Springs: STD
Caster: 1,2
Upper arm mounts: 10deg
Camber: -.5
Rear
Rear Tires: Jaco Purple. You will have to drill the holes out with a 3.5mm bit. I also used another different screw with smaller head to get them to fit.
Tire additive: Hole of rear tire ( TQ Modified) I have also tried Paragon and it`s pretty good aswell
Ride height: 4.5mm
T-bar: Yellow 2mm
Shock spring:STD
Shock Oil: 25wt
Tube Damper Syrup: Hard
Old 10-23-2008 | 02:57 AM
  #229
s.nicholson's Avatar
As the worlds draw nearer lets wish Corally the best and hope the cars place high in the rankings, Packing my stuff and prepping the cars flying out on this monday very excited.
s.nicholson is offline
Old 10-23-2008 | 03:10 AM
  #230
TWISTED
Guest
Posts: n/a
Good luck Simon
Old 10-23-2008 | 03:20 AM
  #231
cannon's Avatar
Excited about racing the car ... or racing to Nana?
cannon is offline
Old 10-23-2008 | 03:56 PM
  #232
OLD 69's Avatar
Company Representative
Good luck champ, aim for nothing less than the top 10
...Ari
OLD 69 is offline
Old 11-04-2008 | 03:47 AM
  #233
mazmo's Avatar
Default Handing problems PHI
Guys, have a handling problem with my Phi & would appreciate your advice.
Main issues are:
1) Major oversteer - middle of fast corners (on & off throttle).
2) Poor stability with quick direction changes - again oversteering.
Have tried various combinations, but just can't seem to get rid of the oversteer
Have attached pdf of my latest set up, would appreciate any guidance
Cheers
Alan
mazmo is offline
Old 11-04-2008 | 01:35 PM
  #234
OLD 69's Avatar
Main issues are:
Cheers
Alan
Alan, try this:
1. Lay top of shocks in one hole front & rear. (i have never run the fronts where you have them).
2. Bump up the rear shock oil 5wt from 25 to 30wt. (i usually run a maximum of 5wt split Fr to Rr)
3. Try a soft Front sway bar (Silver).
4. Lengthen the rear wheel base back to the middle.
Try the above in order one at a time. Let us know how you go.
...Ari
OLD 69 is offline
Old 11-13-2008 | 01:42 PM
  #235
black-knight's Avatar
Lots of new Corally stock in at www.teamcorally.com.au
Including..
The latest 2008 Phi Kits, New 2008 Diffs, and a limited supply of RDX Phi Lipo trays.
black-knight is offline
Old 11-14-2008 | 07:40 PM
  #236
Including..
All those parts are "musts" in my book. The diff is a vast improvement and going to the lipo tray with the SMC 5000 lipo improved my lap times towards the end of a race. Cheers!
Old 12-01-2008 | 04:12 PM
  #237
OLD 69's Avatar
Simons setups from the Worlds and Nationals:
RDX Phi Setup Sheet NICHOLSON 08 Worldspdf.pdf
RDX Phi Setup Sheet NICHOLSON 08 Nats.pdf
Simon finished 16th at the Worlds, Highest placed Aussie at any EP On Road Worlds event.
Back to Back Australian National Titles 07 & 08.
Regards
Ari
OLD 69 is offline
Old 01-05-2009 | 07:02 PM
  #238
A Ilievski's Avatar
I decided to give the Phi another go.
The kit arrived today but ill hold off building it until my hex screws, alloy spool, TRF Shocks, alloy knuckles and what not arrive.
First run will be Fridays practice at Summer Nats, so does anyone have a set up for the IMCC track?
Also any tips for building the 08 diffs? Since the older ones needed some changing to them to get them smoother.
Alex....
A Ilievski is offline
Old 01-05-2009 | 07:36 PM
  #239
Atomix's Avatar
Alex....
Are you planning on running a 1-Way or Spool?
I assume 17.5 is the class of choice?
The 08 diffs will build up very smooth when built to the instructions, no special tricks needed.
Atomix is offline
Old 01-05-2009 | 07:47 PM
  #240
A Ilievski's Avatar
For Summer Nats im planning on running 17.5. But may also change my mind and run 10.5, so im not 100% sure yet. After the Nats it will be 10.5.
I plan on running the spool to start with but may change to one way if needed.
