Corally Phi Thread
Old 07-25-2008 | 02:17 AM
  #211
Originally Posted by s.nicholson
Hi twitch i will post some pics of mine up early next week just after the weekend when i go back to work.
Thanks simon that would be great and what springs do you use with them? Do the corally ones fit? Thanks
twitch_1 is offline
Old 07-25-2008 | 04:08 PM
  #212
SchuMi2's Avatar
twitch...
Here is a couple of pics that might help you out.
Shock tower - You can use either type of ball studs shown.
Shock - Use the kit shock ball cup(on shaft). If you require more droop use the kit shock shafts in place of the Tamiya ones.
Corally springs fit fine. Also Tamiya, HPI, Excel and probably a range of others.
Hope this helps.
Attached Thumbnails Corally Phi Thread-trf1a.jpg   Corally Phi Thread-trf2a.jpg
SchuMi2 is offline
Old 07-26-2008 | 07:48 PM
  #213
Originally Posted by SchuMi2
twitch...
Hope this helps.
Thanks a lot for that just one last thing what is the part number for the blue balls?
twitch_1 is offline
Old 07-26-2008 | 07:56 PM
  #214
SchuMi2's Avatar
Tamiya #53640 5mm Aluminum Ball Nut (Blue)
SchuMi2 is offline
Old 07-27-2008 | 05:32 AM
  #215
Xr Turbo's Avatar
Whats the part number for the TRF shock you guy's are using
Xr Turbo is offline
Old 07-27-2008 | 04:19 PM
  #216
SchuMi2's Avatar
Part #42102
SchuMi2 is offline
Old 07-28-2008 | 12:04 AM
  #217
Xr Turbo's Avatar
Xr Turbo is offline
Old 08-14-2008 | 12:35 AM
  #218
Hey guys i am looking at moveing up to the modified ranks but have heard that the corally diffs you have to rebuild then after every run is this so or not and if so is there a way to fix it or is the new diff that they are bringing out the way to fix it any help would be great?
twitch_1 is offline
Old 08-14-2008 | 03:37 AM
  #219
s.nicholson's Avatar
No this is not the case and also yes the new diff is suppose to get up to 30 runs on a 8.5 motor so a mod motor should produce a fair few runs on the new style diff.
s.nicholson is offline
Old 08-14-2008 | 04:17 AM
  #220
crabboy's Avatar
You can do the team mod to the standard diffs, which is to remove the thrust bearing and replace it with a flanged bearing and the washer from the SP12 or a cone washer.
The thrush copes o lot of crap in it so with it removed the diff is smoother and lasts longer between rebuilds.
crabboy is offline
Old 08-14-2008 | 07:23 AM
  #221
New diff is excellent! Have to think that Corally nailed it...
Still Bill is offline
Old 08-15-2008 | 01:04 AM
  #222
Thanks for that guys it gives me a bit more confidences to take that next step looking forward to it as well.
twitch_1 is offline
Old 08-18-2008 | 03:03 PM
  #223
E-clip's Avatar
Default Swap Ball diff for a oneway
Hi Would anyone be interested in swapping a just rebuild ball diff for a good working front one-way diff ???
E-clip is offline
Old 08-31-2008 | 04:43 PM
  #224
black-knight's Avatar
We are currently clearing out the following stock at very special prices:
In about 3 weeks fresh stock of the New Generation Corally Formula 1 kit will arrive. The Formula 1 kit shares its chassis design with the World Champion 12x 1/12th scale kit. Pricing TBC.
F1 New Generation Flyer - New Generation Chassis Pictures
Will have the Corally F1 on track at SMA in a few weeks.
black-knight is offline
Old 09-01-2008 | 03:30 AM
  #225
TWISTED
Guest
Posts: n/a
I have been running my new Generation F1 for about 2months now and I love it. Will post my set up soon.
Grant Mac
