Originally Posted by Nitrobuggies
(Post 4152252)
Great steering although stock set up i found it would push slightly mid corner (although the driver did remove the plastic cross brace for some reason) i think it gave to much flex. I had to slow right down mid corner, but found entry and exit to be great.
On my local track, this was only a slight issue on two corners, but on all the tight stuff the car was ballistic :) I raised the inside front camber link by 2mm which seemed to help. Broke my personal best race time in the second race (retired from the first race with a dud motor) and set 7 new fastest laps. The drivetrain has loosened up nicely now, though I did raise the front layshaft bulkhead by 1mm which loosens both the front and middle belts. :D |
Good to hear others having good results with the E4.
For those after the E4 FS version, there will be a wait as there are none in the country and team Magic is out of stock too. ...Ari |
Has anyone else had any trouble with the servo saver on their E4??? Mine decided it didn't want to live anymore and detonated tonight, the spring ejected at mach 2 and I lost one of the spring "caps" off the end. Now it doesn't go back together properly... NOT HAPPY! on the positive nothing else on the car broke when it slammed into the wall.
I tried for ages to get the servo saver together but gave up in the end and used a different one.
As for springs you can also use Tamiya (short) springs! Losi Type R also woerk very well.
Originally Posted by bender
(Post 4173079)
I finally got to race mine last weekend and found the same - great turn-in and exit steering but a bit lazy mid corner.
Marcos,
You don't have part numbers and spring rates for the short Tamiya springs do you? I've got TRF shocks on my car simply because all the springs I have are too long for the kit shocks. |
I broke my first drive shaft last weekend... it was in an impact with another car that crashed in front of me so that probably had something to do with it... I am hoping the new 7075 alloy ones don't break
Setup on mine now is still close to stock - 1.3mm front sway bar, moved front top arm to outer hole on the bulkhead... still using the factory springs... this setup calms the steering a little on my track but still gives plenty |
Just want to know what the difference is between the E4 and E4RS and which one is the higher end chassis, or better buy?
Also what is the point of the 2 chassis? Where is the best place to buy one, would probably be looking a 2 so would want some good pricing? Cheers Aaron |
anyone who has known me for some time
Originally Posted by zacabrandy
(Post 4263559)
Also what is the point of the 2 chassis? Where is the best place to buy one, would probably be looking a 2 so would want some good pricing? Cheers Aaron As for performance on the track they would be pretty similar I would think as the geometry and layout is almost identical |
(Post 4260555)
Marcos,
You don't have part numbers and spring rates for the short Tamiya springs do you? I've got TRF shocks on my car simply because all the springs I have are too long for the kit shocks. White-17.54 lbs blue-15.69 lbs yellow-13.99 red-12.35 TAM53630: Tamiya Short On-Road Tuned Springs (Red) TAM53631: Tamiya Short On-Road Tuned Springs (Yellow) TAM53632: Tamiya Short On-Road Tuned Springs (Blue) TAM53633: Tamiya Short On-Road Tuned Springs (White) |
There'll be 2 more maybe 3 more E4's doing the rounds in Sth East QLD soon. Placed our order, now just waiting for the goodies.
Cheers Aaron |
What brand spur gears will fit the E4?
(Post 4280909)
| All times are GMT -7. It is currently 10:08 AM. |
