Nitro Engine Break In
#47
Originally Posted by dee_vee_eight
I've just run in 2 OS Tz's that have been modded by Massive Mods, and have used his method
I think THE most important thing is as Massive says "Preheat the engine" I use a heat gun and get the motor up to near 100 deg C before I put it on the starter box. This stops it "pinching" at TDC
Good luck!
Good luck!
#49
i did the quick methord and my con rod snapped on my sh 28 but after doing some reserch i found out sh 28 have a problem with the con rod snapping i rebult it and and broke it in the slow way but i never replaced piston and sleeve but my engine is running fine now and serpsingly qucker than befor but i will admit i no abit about nitro engines i only no what i no thoug going on forums and taking my engine apart can u plz tell me if i have done some things wrong in rebluding my engine thanks
#50
what about the five tank method is it still valid
